new turbo more problems! - Diesel Forum - TheDieselStop.com
Old 10-18-2009, 11:00 PM   #1 (permalink)
thrtljunky's Avatar
Send a message via Yahoo to thrtljunky
installed new stock turbo on my 95 f-350. was hoping it would fix my no power low boost problem but still have low boost and now the truck is running rough and hesitating on take off. i put all the new o-rings, tightend down all the bolts properly, oil pressure on the gauge is ok, no oil leaking from the pedistal. i am a little frustrated and need a little help on the matter........any ideas?
thrtljunky is offline
Old 10-18-2009, 11:48 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Have you tried running it with the MAP sensor electronically disconnected to see if it runs better on the PCM's default values? If it runs better unplugged you may need a new MAP sensor. Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 10-19-2009, 12:30 AM   #3 (permalink)
thrtljunky's Avatar
i unplugged something on the top of the heater box that also had a tube coming from top of the motor....no change with that still ran the same and have been trying to read other posts on here but dont understand all the abrieviations and not sure where everything is located...still learning about diesels
Old 10-19-2009, 12:08 PM   #4 (permalink)
Cratos's Avatar
My Photos: (15)
have you checked your boots for leaks?? have you checked plenums for leaks?
how is fuel pressure ? have you changed filter and cleaned screan in regulator?
what if any mods need more info !
how long has it been going on ?
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
Cratos is offline
Old 10-20-2009, 07:27 PM   #5 (permalink)
thrtljunky's Avatar
had a diesel mechanic friend of mine look at it...i felt like an idiot...plug came undone from passenger side of motor.. only running on one bank...rookie mistake but live and learn right...thanks guys and will also be pulling the regulater and changing fuel filter....thanks again
