No. 1 diesel Vs No. 2 diesel - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 12-07-2011, 09:44 PM Thread Starter
musstag's Avatar
What is the price for no.2 and no. 1 diesel(kerosene). If no. 1 is much cheaper, could I mix No. 1 and No.2 , say 50/50 ( or some mix %)in one tank and sw to that tank after I get engine running and warmed up. with No. 2 diesel. NO.2 is about $3.90 per gallon in Lower Alabama. Any Ideas on how to cut fuel cost?
'95 Crew Diesel Dually 7.3 automatic (147k 12/02/05) 199k 11/16/11, no cat, bigger DP I was told. "Don't put sides on your Shop, or the Ole Lady will want to store Furniture in it"
musstag is offline
post #2 of 7 (permalink) Old 12-07-2011, 10:30 PM
RT
RT's Avatar
You could go to the alternative fuels section and look into burning waste oils. If you do the filtration correctly, they work great. My fuel costs are less than a dollar a gallon now.
RT is offline
post #3 of 7 (permalink) Old 12-08-2011, 12:53 AM
Alecs's Avatar
My Photos: (12)
#2 in Salt Lake is over $4.00/gallon
That's why my hunt for waste oil starts... NOW. Any suggestions for an amateur? Especially on the collection side of it. I'm aware of the methods and their respective threads, just weary of a consistent supply (SLC, UT).
97 F-250 7.3l XLT 4x4 CC SB e40d
Diamond Eye 3x4 Downpipe
Four Inch Diamond Eye Exhaust, no cat
Tymar Intake
138,00mi as of 11.11.11
Alecs is offline
post #4 of 7 (permalink) Old 12-08-2011, 08:42 AM
Typically, #1 is more expensive than #2. In the northern states where it gets cold in winter most stations sell a 50-50 mix of #1 & #2 anyhow. #1 has less heat energy per gallon than #2 so MPG & HP will suffer with the blend or straight #1.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
post #5 of 7 (permalink) Old 12-08-2011, 09:41 AM Thread Starter
musstag's Avatar
Yea, I don't think you can find #1 at most stations in lower Alabama. They may have a kerosene hand pump somewhere. #1 is easier available up North, gives less mpg, I was wondering how much it cost. You could get it from a fuel distributor I guess, go to their tanks. Yep, cooking oil, used... I don't know, NOT Everyone is gonna be able to get a cheap source of the stuff. Guess it time to look into that again. Some one sell a kit to use the back, or one tank of the f350 as the cooking oil tank with the heater deal. get it started on reg diesel, then sw to cooking oil.
musstag is offline
post #6 of 7 (permalink) Old 12-08-2011, 03:25 PM
greenskeeper79's Avatar
around here kerosene is cheaper because no road tax is applied.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6 E99 CALI DELETE
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #7 of 7 (permalink) Old 12-08-2011, 06:37 PM
edieedie's Avatar
No 1 is not kerosene. kerosene has no additives Bo 1 dose
1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
edieedie is offline
