No communication with scan tool - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 10-09-2008, 04:50 PM Thread Starter
I have a 97 Ford F-350 in my shop that won't communicate with my Genesis. The two grounds , 5 volt and B+ pins on the data link all check out good. There is a Hypertech program installed, but it won't communicate with the downloader either. Has anyone ever had this problem before?
racer5207 is offline
post #2 of 4 (permalink) Old 10-09-2008, 05:25 PM
what is you're issue with the truck will it start and run ? what operating system on you're genesis ? what cable are you using ? if using the smart cable on system 2.0 use the other one i have had problems before also on system 3.0 as well but only twice on system 3.0 i have seen had 2 bad pcm's in my career that will not communicate check the comm wire to pcm maybe it is chaffed through some where
2011 f 350 lariat crew cab dually. Loaded to the nines
2009 FORD F 150 FX4 S /CREW LOADED (BLACK)
2012 POLARIS 550xps SUNBURST ORANGE
2009 POLARIS RZR NEUCLEAR ORANGE 2" LIFT, 27"SWAMPLITWES ON ITP RIMS , POLARIS PERFORMANCE EXHAUST KIT (THIS THING IS CRAZZZY I LOVE IT )
2008 COUGAR SRX (KEYSTONE) 30FT HOLIDAY TRAILER
drford is offline
post #3 of 4 (permalink) Old 10-09-2008, 06:03 PM Thread Starter
Thanks for the quick response. The truck runs but dies intermitently like a bad cps. I have two Genesis one with smart cable 3.0 and one with out , have tried both and hypertech downloader and none will communicate. I will ohm all wiring back to computer as well as B+ to Battery and see what I find.
post #4 of 4 (permalink) Old 10-09-2008, 06:08 PM Thread Starter
I just remembered having this issue when I last updated my older genesis, and I had to download the fix for it off the internet. That was two years or so ago and I haven't had the problem again till now.
