No Overdrive Light - E4OD Trans not going into Overdrive (I think)
I'm still trying to chase down the problem with my E4OD. I don't believe it's going into Overdrive. I only hear 3 gear shifts if I drive it hard.
I don't have any light on the shifter. I think it should come on when I press the OD off button but it doesn't.
My transmission sounds almost like it's skipping 2nd gear. Here's what is happening:
-1st
-shifts and really drops RPMS (like it's going straight to 3rd)
-shifts again and sounds distinctly lower in RPMs but I think it seems like the engine is really winding away at 70MPH. I would think Overdrive should be around 2500RPMs or so. It is a Van so it doesn't have a tach but I'd guess maybe 3200RPMs which I think is high for a 95 PSD E350 1 ton van.
So I wonder if it's not going into OD.
Why would the light not come on at the shifter? It seems like the sound of the engine changes slightly when I press the button but not like it shifted into a different gear. As soon as I let go of the button the tone of the engine returns to normal (VERY slight difference).
Also, If I let off of the pedal in the last gear (whatever the highest gear is while cruising at 70) the engines RPMs drop to idle. It doesn't do this in the other gears.
What I drive:
Ford E350 PSD 1995 --- Fast Diesel 385k Upgrades-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
MB 300d Turbo Diesel 1987 --- Fast and nice to work on
GMC Suburban 6.2 Detroit --- SLOOOW!!!
