No power! HELP! - Diesel Forum - TheDieselStop.com
Old 11-09-2009, 11:58 AM   #1 (permalink)
No power! HELP!
I cannot get the thing above 2300 RPMs. I've replaced the fuel filter and cleaned the screen and the air filter is clean. Took the intake hose off to look at turbo and it seems fine...blades ok and spins free. I cannot figure this out. I hit the gas and it just hangs there, misses, shakes and blows lots of smoke. Any suggestions?
97 F-250 XLT Extended Cab 4x2 Auto...Stock everything
97 F-350 XLT Crew Cab 4x4 Manual, 3" down pipe with straight pipe after cat, 1" spacers in the front 2.5" in the rear, leveling kit with rancho shocks...rides like crap but I just bought it and it's a work in progress. ANY AND ALL SUGGESTS APPRECIATE...JUST PM ME!
Thanks for all the help...can't buy the knowledge on this site!
mkeenan4 is offline
Old 11-09-2009, 12:03 PM   #2 (permalink)
My Photos: (60)
First thought would be contaminated fuel. Have you fueled the truck since you bought it? If so, did the truck run differently before and after fueling?
A few other questions come to mind as well:
Is the check engine light showing?
Have you had the codes read? If so, what are they (if any)?
Smoke white, gray or black?
Can you smell raw diesel fuel in the exhaust?
Mine did something similar some time ago and it wound up being the under valve cover wiring harness on the passenger side front. Check engine light would come on, half of the engine was not running (exhaust manifold on the right side did not get warm).
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 11-09-2009, 12:17 PM   #3 (permalink)
jroller's Avatar
How much boost are you seeing/
2001 PSD 7.3 auto DP Tuner, 4" TBE, KNN Intake (with filter charger), CCV Mod, DB Starter, Stancore GPR, ITP Overboost, John Wood installed valve body. External coolant filter. International Up Pipes.
1994 RAM 4x4 Cummins KNN, 3GSK, AFC Spring, #10 Plate, BD Valve Body, KDP, SCHWITZER S300 turbo 4" TBE.
jroller is offline
Old 11-09-2009, 12:37 PM   #4 (permalink)
Didn't really notice it when I bought it but I don't think it's a contaminated fuel issue. I fueled several times on the way home and have about 1/4 tank left in the rear. The CEL is not on and it idles smoother than my 250 which runs perfect. I'll check the pins on the valve cover gaskets.
I don't have a gauge...how can I tell how much boost?
mkeenan4 is offline
Old 11-09-2009, 01:05 PM   #5 (permalink)
My Photos: (60)
Can't tell boost without a gauge.
Does the truck run smoothly and well up to 2300 RPMs or is it a struggle to get to 2300 RPMs?
If you have the stock intake, what is the air restriction gauge reading?
Old 11-09-2009, 02:55 PM   #6 (permalink)
smooth as can be up to 2300 or so. hit the accelerator and it goes right up and hangs. eventually it will hit max but that's after a LONG struggle. runs smooth once it's there. stock intake and the gauge reads clean (no yellow showing). i disconnected the intake hose from the air cleaner while in the driveway just to test it and there was no change. smoke color seems to be bluish which i assume would indicate oil. checked the fuel in the bowl and it appears to be clean...straw colored. i didn't notice any blow by either.
mkeenan4 is offline
Old 11-09-2009, 10:46 PM   #7 (permalink)
My Photos: (60)
Sounds like a PCM or programming issue. Does the truck have a chip in it or was a programmer used on it? If yes to either I would start by returning to stock tune or pulling the chip to see if it is related to that.
Old 11-17-2009, 09:50 AM   #8 (permalink)
no chip or tuner. could it just be really bad turbo lag?
mkeenan4 is offline
Old 11-26-2009, 08:08 AM   #9 (permalink)
no one has any ideas? i could make a video and post on youtube if that might help.
mkeenan4 is offline
Old 11-26-2009, 09:25 PM   #10 (permalink)
no power
I would check to see if your boost sensor hose is hooked up and there is no holes . I would also check the codes to see the old inactive codes to see what old problems it has had . Does the check engine light work ? When u turn key on does the check engine light turn on I know its stupid but it has happened to me before .
rlincoln1206 is offline
Old 11-27-2009, 08:46 AM   #11 (permalink)
where is the boost sensor hose? i'll check CEL today. didn't think of that...thanks.
mkeenan4 is offline
Old 11-27-2009, 11:01 AM   #12 (permalink)
Nit
look on teh pass side teh small 1/4 hose from teh middle of the manifold next to teh turbo Y pipe to a box just under the windshield, about 20" long. Sometimes you can try unplugging that sensor, adn or you can try unplugging the ICP sensor on teh front of the drivers side head in teh oil rail, next to teh engine liftign hook.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
Old 11-27-2009, 11:52 AM   #13 (permalink)
One other possibility is the exhaust back-pressure valve is closing when it shouldn't. There's a 1/4" steel tube running from the turbo to a sensor on the back of the HPOP reservoir, pass side from centerline of truck, which can clog with soot and cause the EBPV to actuate. You can unplug the sensor; it will throw a code (p0470, I think) but the CEL shouldn't come on. You can also clean out the tube with a piece of 1/8" stranded cable chucked into a drill and a can of carb cleaner. Since I removed my EBPV I've run with the sensor unplugged for years.
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, big front bumper w/4 really bright lights; F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, 265k miles on 25 Dec '10 and counting...
JoshR is offline
Old 11-28-2009, 11:34 AM   #14 (permalink)
boost sensor hose is connected and looks to be in really good shape. the CEL flashes when i first turn on the key so i assume that's working. the lift pump is leaking and will be replacing that soon....would that cause this problem? i'll make a video of it and post a link. it frustrating!
mkeenan4 is offline
Old 11-28-2009, 11:38 AM   #15 (permalink)
Sure it would. You may be getting air in the fuel, and in any case it's not getting the fuel it should. Come to think of it, mine was lacking power before I replaced the pump for the first time.
JoshR is offline
