No Start ! Need Help ! - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 11:47 AM   #1 (permalink)
Powersmoke 95's Avatar
Haven't been on for a while... seems like I am only on when I need help ! lol Anyway... work truck ran fine but began to crank slow/hard start. Tested batteries, one bad, so I replaced both. Still cranked slow, but once started ran great. I figured I would replace the starter and throw in a glow plug relay just because the gpr had been in there awhile and I consider it almost a maintenance item. Heres where it gets weird: I unhook both batteries, replace the starter, replace gpr, hook both batteries back up, and put tools away. I turn the key, wts light comes on then goes out, I turn it over ( cranks super fast! ) , but wont start! ??? I go back, check all the connections I know of ... still no start. After an hour, I figure what the hell, so I shoot a little No No (starting fluid) in the breather. Truck turns over fast, starts up, runs for 2-3 seconds, then dies. I cant get it to fire w/o ether, and cant even get it to stay running at all???? Any ideas?
SOLD: 1995 f350 crew XLT, long bed, 4x4, 5 speed, 3.55 gears, 35" Toyo Open Country's, 102k, Warn 12k winch, AFE stage 2, 4" downpipe, no kitty, Flow Pro, FPR mod, TW 6, Bilsteins, IDM Mod, Ride Rite bags, Fleetguard/Stanadyne/Schaefer's user
1997 F350 CC/LB Auto, auto, leveling kit, 285/75/16 Toyo AT's, FPR mod, soon to have more
1996 F350 XLT Standard cab, 5 speed, 3.55 gears, 323k, FPR mod, daily driver
2001 Excursion Limited E/B, 7.3, 170k-- wife's rig
2006 Polaris Sportsman 4x4 800 EFI Camo
2006 Grizzly 125 Camo
2006 Weekend Warrior FS2300 Toyhauler
Powersmoke 95 is offline
Old 10-27-2009, 12:42 PM   #2 (permalink)
Any ideas?
Old 10-27-2009, 01:03 PM   #3 (permalink)
#22 maxi fuse is good, where is # 22? doesnt blow any smoke when turning over... I am totally lost here guys
Old 10-27-2009, 01:12 PM   #4 (permalink)
Any chance your new GPR is no good. Doesn't seem to explain the dying after a few seconds though. Just a thought.
Tim the 2Lman, '85 F350 2WD CC C6 basically stock 274K miles, '86 F350 reg cab flat-bed DRW 4-speed, '94 F350 powerstroke ZF-5 SRW long bed project soon to be daily driver, 217K miles.
Tim the 2Lman is offline
Old 10-27-2009, 01:21 PM   #5 (permalink)
If everything is plugged in , (double check the IPR )there is a main plug also on the (IIRC) side of the fuel bowl , rt side , try starting it with the ICP unplugged ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 10-27-2009, 01:44 PM   #6 (permalink)
I too am having the same issues.. it started, then ran rough like it was clearing air in the fuel lines (after replacing the fuel filter), then after I took out the batteries to test them, then reinstalled them, got the WTS and Fuel Filter light, but no start.. cranks ok, but no start...
Thinking of replacing the starter, but if there is another solution, I'm all for it.
any help would be appreciated...
btw, in the above post, what is ICP ???
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
Rockdog97 is offline
Old 10-27-2009, 01:47 PM   #7 (permalink)
ICP Injection Control Pressure (sensor).
Old 10-27-2009, 01:49 PM   #8 (permalink)
Thanks Tim.. is that the little sensor on the right side of the fuel filter bowl with the red wire coming out of it?
Randy Wheeler
Old 10-27-2009, 02:06 PM   #9 (permalink)
No, it's the sensor screwed into the driver's side head at the front of the engine top side behind the A/C compressor with 3 wires coming out of it.
Old 10-27-2009, 02:14 PM   #10 (permalink)
think i found the problem... i dont know what the sensor is called, but the two wires coming out of the connector had the insulation worn off and were touching each other.. spread them apart and fired up?? hope that was it. ps.. it is between the fuel bowl and hpop..plugs into the backside on the bottom of the hpop.. black connector and has a wire spring that swings over and snaps the two connectors together. any ideas what that sensor is?
Old 10-27-2009, 02:19 PM   #11 (permalink)
well, i went back out to properly repair those two wires, and noticed that whatever sensor it goes to moves... wth??? it slides left and right a total of about 1/2 inch... could that be my problem, not the wiring? i am sure that the sensor moved while i was unplugging/plugging...
Old 10-27-2009, 02:20 PM   #12 (permalink)
Thats the IPR & the nut & spacer may be missing....
There is a pic of the nut and the spacer ...here...
Rick.....
Old 10-27-2009, 02:28 PM   #13 (permalink)
man, i don see any loose parts in the valley... i spose the nut could have come off... i cant really see where there should be a nut tho... will that sensor slide side to side or just come out if the nut was gone?
Old 10-27-2009, 03:28 PM   #14 (permalink)
Are these two one in the same???
Randy Wheeler
Old 10-27-2009, 03:37 PM   #15 (permalink)
The three wire on the head is the ICP sensor , the other is the IPR on the lower rear of the HPOP..
Rick.....
