No Start ! Need Help ! - Page 2 - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 03:40 PM   #16 (permalink)
Originally Posted by Powersmoke 95 View Post
man, i don see any loose parts in the valley... i spose the nut could have come off... i cant really see where there should be a nut tho... will that sensor slide side to side or just come out if the nut was gone?
The coil would tend to stay there ,when running , It is supposed to be held in place with the spacer & a 3/4 tin nut.. It won't run well if at all if the nut is gone...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 10-27-2009, 04:16 PM   #17 (permalink)
Powersmoke 95's Avatar
I will look again for the missing pieces. Thanks to all for your help and input- that is why I come here!
SOLD: 1995 f350 crew XLT, long bed, 4x4, 5 speed, 3.55 gears, 35" Toyo Open Country's, 102k, Warn 12k winch, AFE stage 2, 4" downpipe, no kitty, Flow Pro, FPR mod, TW 6, Bilsteins, IDM Mod, Ride Rite bags, Fleetguard/Stanadyne/Schaefer's user
1997 F350 CC/LB Auto, auto, leveling kit, 285/75/16 Toyo AT's, FPR mod, soon to have more
1996 F350 XLT Standard cab, 5 speed, 3.55 gears, 323k, FPR mod, daily driver
2001 Excursion Limited E/B, 7.3, 170k-- wife's rig
2006 Polaris Sportsman 4x4 800 EFI Camo
2006 Grizzly 125 Camo
2006 Weekend Warrior FS2300 Toyhauler
Powersmoke 95 is offline
Old 10-28-2009, 10:42 AM   #18 (permalink)
Originally Posted by action4478 View Post
The three wire on the head is the ICP sensor , the other is the IPR on the lower rear of the HPOP..
Any chance you have a picture of these? or a diagram of where the ICP and IPR are located???
Also,
I around last night to see if I had any loose wires and found a small, oval-shaped plug was disconnected. This plug is on the driver-side bottom of the fuel bowl. Black plug with a small flat-pin on the bowl side of the terminal - wire side of the plug is oval-shaped and is black. There is also a small wire located below this plug, but that was connected.
I tried plugging the black oval-shaped plug back in but not sure if I got it all the way in, as its pretty hard to push on (no hand space!).. Can anyone tell me what this plug is? I'm thinking I may have knocked it off when I tried to stuff some rags beneath the fuel schraider valve while testing for fuel pressure/flow.
The wire-side of the oval-shaped plug was pretty dirty, so not sure if it'd always been unplugged or just got dirty while I was filling and re-filling the fuel bowl..
Randy Wheeler
1997 F350 4x4 Crew Cab PSD Lb
Rockdog97 is offline
Old 10-28-2009, 10:55 AM   #19 (permalink)
the wire that was unplugged on the back of the bowl is the fuel heart , you many want to leave it unplugged . The ICP is a three wire sensor on the Left head near the lifting ring , the IPR is in this pic,.....
Rick.....
Old 10-28-2009, 04:28 PM   #20 (permalink)
thanks for the link.. any chance you can email me the larger version of that pic, as it's hard to read at the scale you have it. I cant view a larger image cuz I'm not a webshot user...
rockdogz97@gmail.com
So the oval connector isn't required? not sure what you mean by "fuel heart." does this wire need to be connected in order for the rig to start/run? It does look like it has been off for some time, but I'm not positive.
HA.. I looked at your other photos and the little oval connector looks just like your photo of the cannister heater hookup-water sensor
Thanks in advance.
Randy Wheeler
Old 10-28-2009, 05:29 PM   #21 (permalink)
My bad , should have said fuel heater
When I click on the link , the pic is huge ...
Rick.....
Old 10-28-2009, 05:34 PM   #22 (permalink)
hows that ....
Rick.....
Old 10-28-2009, 05:41 PM   #23 (permalink)
Yeah! I can read it... and see what the things are and where they are...
thanks for the clarification on the fuel heater.. I guess I'll just leave it unplugged..
Randy Wheeler
