Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-29-2008, 11:00 PM   #1 (permalink)
No start-oil in fuel canister
I just bought a 95 F350 from a repo yard....got it dirt cheap because it won't start. Truck has 220K miles.
I brought it home tonight and did the basic checks...new batteries, found out the glow plug relay wasn't working, so I jumped it and the plugs pull a lot of amps so they're working, checked the oil level in the HPOP and it was full, oil pressure reads good while cranking, I forget to notice the tach...
I then pulled the fuel canister and it was full of nasty, black, oily-looking fuel. I drained the canister and had a buddy crank the engine while I watched the bowl. It filled up pretty quickly again but it filled back up with the same nasty black fuel.
I've done some searches, and that sounds like injector o-rings? Is that right? If so, how does that oil get mixed with the fuel going into the fuel canister? Would this cause a no-start situation?
Thanks!
Casey
1996 E-350 Van Cutaway, 7.3L PSD, E4OD, Dana 70 dually with 4.10 gears, Reading enclosed utility body, 160K miles....
1995 Chevy K1500 Tahoe, 6.5L TD, NP241, 4L80E, 3.42 gears, Kennedy Diesel OPS harness and FSD cooler kit.
1981 Chevy 3/4 ton converted to 6.2L TURBO DIESEL, bored .040" over, 6.5L pump, turbo injectors, DSG timing gears, lowered compression w/ceramic-coated pistons, 17 lbs of boost....4 speed auto, custom built 4" exhaust, 4.10's, keyless entry, etc. etc....See my photos
arveetek is offline
Old 07-29-2008, 11:23 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (18)
Check the main oil level as well as the HPOP level. The HP oil can get by the injector o-rings and get into the fuel system through the fuel rails (and eventually into the fuel tank(s) via the return line). When my o-rings catastrophically failed at 175k, I used 8 quarts in 150 miles (or less since there was only 150 miles on a fresh oil change). It could also be algae in the fuel if the filter is black and slimy looking. Then you would need to probably drain the tanks and treat the fuel system with biocide. Cheers!
1994 F350 CC DRW 2WD PSD (ALF4), ZF 5 Speed, 4.10 LS, SBC Con-O SMFW/Clutch, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Stancor GPR, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro (pre-turbo) , Relocated Block Heater Plug, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 07-30-2008, 12:22 PM   #3 (permalink)
HPOP oil level is fine, but the main crankcase oil level is low. It looks like we need to clean out the fuel system, replace the injector o-rings, and then go from there....
Casey
arveetek is offline
Old 07-30-2008, 04:02 PM   #4 (permalink)
Got it started!!
Fresh batteries, found a blown fuse going to the GPR, topped off the oil level, and vroom! It took a lot of cranking and it slowly started firing on all cylinders, and then it smoked like a freight train for a few minutes. Took it out on the road and it took a mile or two to clear out the oil, but then it ran clean and clear. After sitting for a few minutes, it was hard to restart. Would this still be the o-rings?
Casey
arveetek is offline
Old 07-30-2008, 05:30 PM   #5 (permalink)
Could be .....If it is from the uppers ,,,you'll see(with the valve covers off), oil bubling up from the base of the injectors ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 07-30-2008, 07:21 PM   #6 (permalink)
blageurt's Avatar
Mine did that too and then it never started again. # 6 Injector upper o-ring was gone.
Actually all of my o-rings were in rough shape . . . can't believe it ran as good as it did.
International is alot cheaper than Ford for the parts. If you have the time replace them all and don't look back.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 07-30-2008, 10:35 PM   #7 (permalink)
Already bought the o-rings for all injectors from Ford today!! Oh, well.
We'll get the o-rings replaced and check out all the other parts while we're at it. She runs good and strong once you get her started.
I'll have to let you in on a little secret...just don't tell anybody....
We got the truck (1995 F-350 single wheel 4 door 4x4) for only $1200!! The repo shop said that it needed a new motor.....
Casey
arveetek is offline
Old 07-31-2008, 02:29 AM   #8 (permalink)
brian213's Avatar
Wow! VERY VERY good deal, and good job getting her running again! Best of luck with the o-rings.
-Brian
1995 F-350 PSD XLT CC/LB >250k miles...AirLift 5000 rear bags, excellent!
Have replaced the water pump, power steering pump & A/C compressor just prior to or via failure.
I roadrace a 125GP bike..haul it with a huge truck & a 20' 5500# trailer...whee!
It's looking better: replaced fender, front bumper & hood hinges.
-- pulling a 20' trailer and 1997 Honda RS125
brian213 is offline
