Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 08-04-2008, 02:38 PM   #1 (permalink)
No Turn Signals
I lost my turn signals the other day after I hooked up to a trailer with bad wiring. I checked the number 7 fuse in the dash and replaced the flasher in the fuse panel. I even tried a different multi-function switch from my dad's truck and that didn't do it. I have 4-way hazard flashers and brake lights. Any ideas on the turn signals?
Thanks in advance,
Zach
1996 F250 245K Auto 4:10's 3" Downpipe Straight Pipe Ford APCM 203* T-stat K&N(For Now)
Badger174 is offline
Old 08-04-2008, 05:07 PM   #2 (permalink)
eagleeye's Avatar
Your running lights and turn signal fuses for your trailer harness is located under the hood in the power distribution box. I think they are 10 amp for the turn signals and 25 amp for the running lights.
Travis
1996 Extended Cab Long Bed XLT, 4x4, 3.55LS, Tymar Intake, Diamond Eye Performance 4" Exhaust, Meyer C-8 Plow, Timbren Load Levelers
Case 1845c Uni-Loader
PowerStrokes And Duck Hunting-It Doesn't Get Any Better
eagleeye is offline
Old 08-04-2008, 08:36 PM   #3 (permalink)
It's not just the trailer, I don't have any turn signals on the truck with or without a trailer. So even if the fuses for the trailer harness are blown wouldn't that just affect the trailer?
Old 08-04-2008, 09:54 PM   #4 (permalink)
STurbo90's Avatar
My Photos: (9)
Yes, the truck lights should still work.
If you have brake and hazards the wiring has to be good up to the mfs,
you said you checked the #7 fuse, but did you actually verify there is power there? The fuse may be good, but there might not be power.
could also be a break in the wiring from the fuse to the flasher to the mfs.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 08-05-2008, 10:42 AM   #5 (permalink)
I have power to the 7 fuse and to the in side of the flasher. So that means a break in the wiring between the flasher and the MFS? Can I use a piece of wire to jump the flasher and just check for a solid turn signal? I know that it's rare but I guess I could have gotten a bad flasher from napa?
Old 08-05-2008, 12:12 PM   #6 (permalink)
STurbo90's Avatar
My Photos: (9)
or you could just check for continuity on the other terminal of the flasher receptacle with the switch in both positions.
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 08-05-2008, 12:13 PM   #7 (permalink)
Update: I just checked the power to the harness at the MFS and I had solid power with the key in run? Shouldn't that be a pulsating voltage from the flasher?
Old 08-05-2008, 12:18 PM   #8 (permalink)
STurbo90's Avatar
My Photos: (9)
which wire? I think the light blue wire is for turn signals, there should be constant power there for flash-to-pass on another wire,
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 08-07-2008, 06:43 AM   #9 (permalink)
Yes the light blue wire. Then I checked the power in to the hazard flashers and it was a solid 12V as well and it runs on a separate flasher and I know it works. I am really stumped, I'm almost ready to go buy a new MFS but I'm pretty sure that's not my problem... And as soon as I buy a new 180 dollar MFS and put it in the truck it's mine and I can't return it?
Old 08-23-2008, 12:41 PM   #10 (permalink)
I am having the exact same problem with my 2005 F250 V10. I had a trailor attached when it went, but same problems, no bad fueses,new flasher, new multifunction switch.
Did you ever resolve your issue?
Thanks,
Mike
nightbreed is offline
