No Turn Signals Nor 4 Way - Diesel Forum - TheDieselStop.com
Old 07-10-2009, 08:04 PM   #1 (permalink)
96 F350 Manual Trans.
I Blew The Turn Signal Fuse And Replaced It. I Only Checked It While It Was Parked. They The T/signals Worked. Now I Have No T/signals Nor 4 Ways. A Mechanic Friend Checked All The Fuses In The Dash And On The Fender All Aok. I Just Changed The Little Round Blinker Can In The Fuse Panel By Your Left Knee. No Good. The Flash Tube Was Good. I Searched This Site And Found There May Be Another Flasher Behind The Fuse Panel . I Will Check This Tomorrow. If Anyone Has An Idea I Could Sure Use It. Thanks
WCJR is offline
Old 07-10-2009, 09:29 PM   #2 (permalink)
I would suspect the multi-function switch on the steering column. Try engaging/disengaging the flashers a few times--I had a similar problem long ago and after messing with the flashers on the MFS, everything began working OK again. Worst case, buy a new MFS, they're not terribly expensive and not too bad to change.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
