OBS high mileage issues - Diesel Forum - TheDieselStop.com
Old 10-27-2009, 09:38 PM   #1 (permalink)
Hello, I am in the market to buy a diesel and I really like the OBS fords. How many miles is too many for these trucks? I mean with normal wear and tear, is there a time when these trucks get too worn out? I have found several trucks in the low to mid 200k mile range and im not sure how much more they have in them... I hope my questions make sense. thanks in advance for the help.
-Jeff
Macy is offline
Old 10-27-2009, 09:44 PM   #2 (permalink)
-Jeff
200K is like an teenager for an OBS PSD. 500K is the average for them, there are some with 1000k in the clock. Well I forgot to mention that all depends in the regular maintenance
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 10-28-2009, 02:05 AM   #3 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I just bought my truck with 250k on the clock and it runs like a bear. I did of course have a lengthy conversation with the PO about his maintenance schedule with the truck and he assured me of his vigilant maintenance and the condition of the truck reflects it. If it needed it it got it. I only paid 4400 for mine so that might give you something to go off of but I do think I got mine at a killer deal. Good luck in your hunt.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 10-28-2009, 10:05 AM   #4 (permalink)
So basically I just need to
ale sure they have maintenance records? Could someone give me a list of things to check?
Macy is offline
Old 10-28-2009, 10:52 AM   #5 (permalink)
Look in this link, there are some part with some advices, BTW its a great page
[FONT='Verdana','sans-serif']http://pages.prodigy.net/stevebaz/_import/pages.prodigy.net/stevebaz/index3.html[/FONT]
Old 10-28-2009, 11:04 AM   #6 (permalink)
There's a 1997 Ford diesel van on ebay right now with 745,000 miles on it. I guess they can go a long time
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
Old 10-28-2009, 11:36 AM   #7 (permalink)
I've bought four over 200k PowerStrokes over the years. None have had engine problems other than with the glow plug system. All but one have needed to have basically the full suspension/steering systems gone thru. Ball joints, tie rods, shocks, brakes, etc. If you can do this yourself and use quality lifetime warranty parts you'll have a solid truck for years to come at a reasonable price. Find a diesel expert and pay to have a thorough prebuy inspection done with a PowerStroke specific scan tool. This will tell you a lot. Know how the truck should perform when you drive it. You can tell if it is down on power if you have driven several. Pay attention to the clutch on a 5-speed. The dual mass flywheels fail and there are many posts on that. Problem can be solved with a Luk single mass flywheel and clutch. The automatics are somewhat weak with the earlier years being the worst. Can be solved with a BTS transmission. Many posts on that too. I'd also take a real close look at the body seams on the cab. The drip rail area over the doors appears to have sealant that starts cracking and would likely lead to rust. Maybe someone else can tell you more about that....I've just noticed it on a few OBS trucks.
'94 F350 4x4 PowerStroke, 5-speed, 4.10 gears, crew cab, XLT, Luk Clutch, ZF-47, Hydroboost, AIC, Max A/C Assist, 95.5 radiator and degas bottle 315,000 miles
'96 F350 4x4 PowerStroke, auto, 4.10 gears, crew cab, XLT, DRW conversion, AIC, 451,000 miles
'02 F350 4x4 PowerStroke, 6-speed, 3.73 gears, crew cab, XLT, DRW, AIC, 180,000 miles
Diesel_Aggie is offline
Old 10-28-2009, 08:34 PM   #8 (permalink)
Ok, I think I have enough to start looking. I dont know how easy it will be to find someone here in Jacksonville who knows OBS PSD's but I will give it a shot. Thanks guys for all of your help...
Are the crew cabs worth more than the ex. cabs? I would like to have a crew but they seem to be harder to find.
Macy is offline
Old 10-28-2009, 09:01 PM   #9 (permalink)
Talking
Are the crew cabs worth more than the ex. cabs? I would like to have a crew but they seem to be hard to find.
You are welcome. IMHO the CC are more worth than the EC. I would like to find one with short bed, that are ever more harder to find, I need one because the kids are growing.
Good luck in your search.
Old 10-28-2009, 10:39 PM   #10 (permalink)
I looked for a year and a half for a short bed 4x4 with a 5 speed. It had 180k, came from a lot that got it through the usual auction. I did find out it came from Elmo UT, a tiny town I hear. I had no history to go on and it had 180k. It has 220k now, and the only thing that really NEEDED replaced on the powertrain was the injectors which are pretty much done by 200k. Not necessarily going to fail, but kind of like worn spark plugs.
I completely agree with the post on the suspension and chassis rebuild as you go.
Diesel Mechanic 28 yrs
Garbage_Mechanic is offline
Old 11-04-2009, 08:53 AM   #11 (permalink)
Sounds like it was worth the wait... I am thinking I may offer my fox body mustang for a trade here pretty soon.
Macy is offline
