Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-03-2009, 10:17 PM   #1 (permalink)
Cool OD off switch not working
Greetings all, My OD on/off switch suddenly stopped working. It seems like my OD is still working I just can't turn it off. It was quite a nuisance while towing a trailer today up hills. Does anyone know if there is a fuse? Do the buttons go bad, I know they just pop out? Thanks for your help!!!
1997 F350 XLT, CREW CAB, POWERSTROKE, AUTO,
286,000 MILES. TYMAR INTAKE SYSTEM. 3" down pipe,
4" exhaust. 14-16 mpg, RSK with SD springs, 315 Dick Cepek Mud tires on 10" rims and BULLYDOG 4 BANKS CHIP, Bilstein Shocks
dieseldo is offline
Old 07-04-2009, 12:43 AM   #2 (permalink)
96P_Stroke4x4's Avatar
Send a message via AIM to 96P_Stroke4x4
i had that happen to me. turned out that the connection in the steering column came apart. you might want to check that.
Matt
'96 F-250 XLT,x-cab,4x4,BTS E40D,266k,dana60,Swamps175/173s,Dieselsite Adrenaline HPOP,CPR Fuel system,rear discs,4" dp to 6" exhaust w/ twin 6" stacks,Tymar,Autometer Lunar Boost,Pyro,and Tranny Temp,white-faced gauges, intercooler,diamond headlights and corners,onboard air,HX mod,Twildman 6-position chip,led 3rd brake light,2 green neon underbody kits+extras,clear cab lights,alteeza tails,4 corner strobes,Sirius satellite,kenwood mp3 player
NRA Life Member
North-South Skirmish Association
"Gotta love the fresh smell of diesel and black powder in the morning!"
96P_Stroke4x4 is offline
Old 07-04-2009, 12:47 AM   #3 (permalink)
Buttons can go bad. Lost one off my shirt the other day. LOL
No, really switches fail. That's not to say this is your situation. Find the wires to it and test it. I'm to lazy right now to go look at a schema of the system. So your on your own there. But it should be fairly easy to find and test the switch. Worst case you can by pass it with your own switch.
Perhaps someone will have been here before and know the wires to check.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline
Old 07-04-2009, 09:10 AM   #4 (permalink)
Mark Kovalsky's Avatar
The wires to check are in the steering column where they enter the shifter handle. They wear through. Either fix the wires or get a new shifter handle for about $50.
Mark
Mark Kovalsky is offline
Old 07-05-2009, 07:13 AM   #5 (permalink)
Thanks guys, guess i'll pull the steering wheel off today and make sure i'm still plugged in........
dieseldo is offline
Old 07-05-2009, 08:15 AM   #6 (permalink)
Don't pull the steering wheel! You'll never get to the wires that way. Take the plastic cover off of the column.
Mark
Old 07-05-2009, 08:33 AM   #7 (permalink)
S95
i had an OD wire issue, the wires had been pinched where they went by the corner of the MFS block and one was broken inside the insulation. they are very small guage wires. i was able to do the micro solder repair, relocate the bundle so it was clear of future snags, been good for about 4 years now.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
S95 is offline
