2005 KR CC SB Auto 6.0L - 4in straight to the back no muff or kitty, Upfitter High Idle mod, Blue Spring
1996 F250 Crew Cab LBox 5sp "Sold"
1967 Ford Fairlane 2Dr Post factory radio delete non ac, manual brakes, manual steering car. 80% restored working on interior Body and Paint done- 390FE stock oil eater, C6, Starshifter, Micky T Indy Style 60 Series on back. Originaly Black repainted black
1972 Ford Gran Torino Fastback 351 Cobra Sold
1979 F350 Custom Crew Cab Short Box replaced Torino for project vehicle..
I like their comments ;> makes me feel like im taking care of it well when i work it like a dog ;>
Wear looks pretty good in the first sample from your F250. Iron was above average but if you
work this engine hard that would explain it. All other wear is average so we doubt that it shows a mechanical
problem but we'll be sure to keep an eye on it next time. Universal averages are based on an oil run of
~5,300 miles. The oil was in good shape physically, containing no moisture, fuel, or coolant. The air and oil
filters are working well too (see silicon and insolubles). The TBN read 8.5, plenty of active additive
remaining. A TBN of 1.0 is too low. Nice engine.
Like they said, iron is a little high, but fantastic otherwise. Go to Bob is the oil guy forums and read up on oil and oil reports. The high TBN means the oil can go much longer safely. You could probably go 10,000 miles on that oil. Calcium, phosphorus, zinc are good numbers so good oil choice whatever it was.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
I just got my "kit" in the mail last week. I've got 5k on my current Rotella and I'd like to send it in and get results before I change my oil again. How long did it take from the time you sent in the sample to being in receipt of the report. Oh, and what oil do you run? I run the Rotella with wix filter...
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
i run wix or pronto filters, rotella 15-40 and i took sample mailed it the 6th and just got it yesterday the 19th in my email
