oil in coolant - Diesel Forum - TheDieselStop.com
Old 01-26-2009, 02:48 PM   #1 (permalink)
oil in coolant
my 97 350 is getting oil in the coolant. not alot, but its noticable. the truck runs fine and has plenty of power, but last week it started leaking coolant off the backside of the motor. i was told it could be the intake manifold gasket. any other ideas.
shooter63 is offline
Old 01-26-2009, 02:51 PM   #2 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
oil cooler or head gaskets
Early 1999 F350 XLT Crew Cab 4r100 3.73LS 4x4
bockhold is offline
Old 01-26-2009, 05:38 PM   #3 (permalink)
diesel_brad's Avatar
Hope it is just the oil cooler or the o rings for the cooler. Not tooo bad of a job.
86 F250 6.9 4spd 4x4 6"+315s's(coming soon POWERSTROKE,D60&zf5 )
00F350 Xcab Dually 7.3.ZF6, 4x4 SOLD
94 Lightning, Full Bassani exhaust,underdrive pullys, CAI, new paint w/ stripes
96F350, 4dr, 460, ZF5, 6"lift, 35"thornbirds, banks torque tubes, 3"custom bent exhaust, bbk throttle body, stull grill, clear front turnsignals, lund visor, 3.55gears
1980 F350 PULLIN TRUCK, 429, C6, detroit lockers f&r 10.25/D60 33' BFG muds
diesel_brad is offline
Old 01-26-2009, 11:10 PM   #4 (permalink)
bockhold's Avatar
me too. its a pita to change the oil cooler
bockhold is offline
Old 01-27-2009, 02:36 AM   #5 (permalink)
PSDfreak's Avatar
My bet is on the oil cooler as well
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 01-27-2009, 02:41 AM   #6 (permalink)
169stang's Avatar
My Photos: (5)
If it's oil (leaking outside) from the oil cooler, it's the inner set of O-rings. If it's coolant, than it's the outer set of o-rings. If either is mixing than it's the outer o-rings....not that it matters. i'd hope you would replace all of them
I just went thru this last weekend. I've heard people say "you may have to jack the motor." I could see any other way but to jack it up about 1".
Pretty messy, but well worth it! I hear they get $600 from the Stealership to R&R the oil cooler. I spent a whole $40 to do it myself...not including the new oil and coolant.
1997 F350 7.3L CC DRW 2wd
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
http://good-times.webshots.com/album...ost=good-times
169stang is offline
Old 01-27-2009, 10:28 AM   #7 (permalink)
cool deal, thanks for the imput.
