Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 02-24-2008, 08:26 AM   #1 (permalink)
BeauCefus's Avatar
Oil Cooler Replacement Concerns - 96 F250
I just recently bought my first new used 1996 F250 Powerstroke.
It has a lot of rust underneath as the previous owner used to plow snow.
The oil cooler is VERY rusty and has had a slow leak as far as my mechanic
can tell. The first mechanic wanted to just replace the seals, but the new one
feels the oil cooler looks so bad that just replacing the seals only may mean that it would all have to come off again if the leak persists and the actual cooler may have a leak. Better safe than sorry he says & we should just replace the entire thing.
How much do you think I should expect to spend on this repair ? Hopefully it will take care of the leak in question. I sometimes hear of replacing one part and then another goes bad right afterwards. Any comments or suggestions would be greatly appreciated.
Joyce Whitehead
Arlington, Va.
BeauCefus is offline
Old 02-24-2008, 08:41 AM   #2 (permalink)
Supporting Member
Excavator's Avatar
My Photos: (11)
Hi guy/gal and welcom to TDS
Most trucks just need the o-rings and gaskets to fix the leak however one of my 3 Powerstrokes was a salt /plow truck that I still plow with and when i bought it it too had much rust on cooler and oil pan. I did replace the cooler tube and o-rings and gaskets. Here is a link to get all the parts you would need.
Powerstrokeshop.com
You could do the repairs if you are handy as we could help you out.
If you take it somewhere it could get pricey
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 183000 miles
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Excavator is offline
Old 02-24-2008, 10:25 AM   #3 (permalink)
fixithud's Avatar
When I have issues such as yours I get prices on the parts for both the good and the bad scenarios.
The oil cooler job is about 2 hours +/- if you have never done it. I figure in my mind how bad the job is and how much it would be worth not to do it again.
If the cooler is suspected of being bad itself, probably just the tube, the ends are make of pretty healty material. I think the tube costs the better part of 200.00. Sure would be good if you could verify the leak before you pull it off.
I think the o rings are about 50.00 for the kit now. It is a diy job, a press makes the easier but a wood working bar clamp can do the job. Anytype of clamp that the tube will fit into and apply a moderate amount of pressure. You don't need 10 tons of pressure. Maybe even a ratchet strap would do it.
Do a search for the directions and DON'T LOSE the valve in the filter end cap. It is a spring and plunger setup that may try to pop out.
Hud
95 F-350 cc xlt 4x4 srw
tymar air filter
4" exhaust with dp
gutted ebpv
kitty gone
3 position chip from Tymar, stock, tow, race.
300,000 miles in 10-08
99 F-550 xl 2x4 drw
12' Johnie Gregory Dump
six speed
stock with 230k
fixithud is offline
Old 02-24-2008, 11:28 AM   #4 (permalink)
I think a '96 truck is new enough you shouldn't have to worry about losing any of the valves in the oil fitler housing. I have a '94 which the valves are only held in by punch marks. When I did my oil cooler a few months back both valves fell out but I could only find one of them so I also had to replace my filter housing. Mine was leaking oil and just o-rings probably would have been enough but the tube section was pretty bad looking so I just replaced the whole thing. I got the tube section and o-rings/gaskets through powerstrokeshop.com and they were very helpful.
'94 F250xlt ext. cab. ZF5-speed 4x4. DPP downpipe. Tymar intake. Tymar coolant filter. LF9691 primary filter. LF777 bypass oil filter. Electric fans. 70 psi fpr. 10k mod. 1.0 turbo housing. Boost blanket.
sdan27 is offline
» Sponsor Links
»Garage Storage and Cabinets
