oil filter relief valve - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 11:05 AM   #1 (permalink)
d78
This is my first post,but I have used this site for help and advice many times-Thanks to everyone.Yesterday I was changing oil,when I removed the filter the relief valve in the oil filter housing droped out.I replaced the spring,fiber disc and restaked the washer the best I could.I think to fix it right I should replace the housing.My question is has anyone else had this problem,and if and when I replace the housing does the oil cooler and block heater come with it?Thanks
1996 F350 chip,downpipe,gauges,about 120,000mi,new warranty engine at 60,000,3.55 gears,auto
d78 is offline
Old 03-04-2005, 11:09 AM   #2 (permalink)
Tom S's Avatar
My Photos: (20)
Re: oil filter relief valve
I believe those parts are all separate. Others have restaked the piece without a problem so you should be fine. The newer ones have a snap ring to hold it together.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood, 14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 03-04-2005, 05:18 PM   #3 (permalink)
I was just wondering, what would happen if this wasnt installed correctly, my friend said his came out and he just stuck it all back in there and it looked right, but the track has been running fine, would this cause any damage without knowing. I mean wouldnt the gauge tell you something is wrong if it wasnt working correctly.
Ford certified diesel tech
96 PSD reg cab 4x4 auto 4.10 LS rear xlt. 4" superlift 35" BGF Muds on 16.5 mickey thompsons, dual stabilizers, 3" glass cowl hood, custom american patriot headlinner, Beans stage I's, TS Performance 6 pos. chip, SD HPOP, BB in fuel regulator, custom intake, 3" downpipe, 4" straight pipe exhaust and 5" tip. All aluminum radiator, 6.0 trans cooler. Banks pyro, trans temp and boost gauges on the pillar. TransGo shift kit, billet converter. 10" rear drup bumper, custom droped hitch receiver billet grille, custom front bumper with fog lights and billet grille, diamond cut headlights, clear corners and markers. Viair compressor, one gal. tank and dual air horns.
90 mustang 347 race car.
05 f250 red supercab 6.0, suncoast auto trans, 4x4, long bed fx4, grey interior. atc 275cc injectors, turbonetics ceramic coated 70mm turbo, head studs, aeromotive fuel system, sct with innovative tunes, dual 5" stacks.
fordboyyfm is offline
Old 03-04-2005, 05:37 PM   #4 (permalink)
You wouldn't be able to tell by the gauge. Oil analysis would show the contaminants in the oil rising rapidly. There is a TSB on the relief valve falling out. I don't have it handy but I believe it shows the proper order of parts reassembly. If you do replace the housing, it is just the end the oil filter attaches to. You'll want to replace the oil cooler o-rings while you're in there. The new style the check valve is held in with a clip.
Oil Cooler Housing 94-97; Updated snap ring retained check valve
(Ford)F81Z-6881-BA
Oil Cooler Housing Gasket (front)
(Ford) F7TZ-6A636-A
(International) 1831666C1
Oil Cooler Housing Gasket (rear; oil filter end)
(Ford) F4TZ-6A636-AA (97-up)
(Ford) F4TZ-6A636-B (96-before)
(International) 1831665C1
Oil Cooler O-Rings (one each to seal cooler at each header)
(Ford) E3TZ-6C610-A
(Ford) E4TZ-6K649-E
(International) 1807563-C1, Inner 1804414-C1 Outer
JOAT is offline
Old 03-04-2005, 07:46 PM   #5 (permalink)
d78
Thanks for the info.I think I will change oil again soon and see how the valve looks.I think the washer that I staked in will stay in place,but the fiber disc would stick open sometimes when I checked it-maybe it always did this-I never had a reason to check it before.
d78 is offline
Old 03-04-2005, 10:50 PM   #6 (permalink)
I have about 80k on a staked oil valve. Works for me. [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is online now
Old 03-05-2005, 10:39 AM   #7 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Welcome to the site!
The new filter adapter header with the snap ring retained valves is about $150. Staking the old parts back in is fine as long as you have all the parts (spring, disk, washer). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
