oil leak after cold weather start, then stop - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-24-2006, 12:41 PM Thread Starter
1995 7.3 powerstroke, 100,000 miles (have changed injectors, glow plugs). In cold weather (32 degrees) engine hard to start; then very rough, noisy idle; then when immediately shut off (without driving), considerable oil found on ground. Otherwise runs great. Oil seems to be an overflow or something. Does not happen when engine is warm or weather is warm. Any ideas?
ysiad is offline
post #2 of 5 (permalink) Old 03-24-2006, 04:13 PM
Re: oil leak after cold weather start, then stop
Check the external oil cooler. Mine does the same leaking from there but only when quite cold. Dealer says it has a tiny crack in it & that it isn't unusual! Also check your glow plugs could cause rough idle when cold.
1996 F-350 CrewCab 4x4 260K+ 3"DP
milkmaster is offline
post #3 of 5 (permalink) Old 03-24-2006, 05:20 PM
tallfarmboy's Avatar
My Photos: (11)
OR, check your EBPV housing. Oil LOVES to come out of the actuator barrel. I had that problem and solved it by cutting the barrel off and welding the oil holes shut...
TFB
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust
tallfarmboy is offline
post #4 of 5 (permalink) Old 03-25-2006, 01:38 PM
Ysiad Man I wish I had a 95 with just 100k.
I've seemed to have experienced the same leak a couple times over the years. It was disturbing seeing the puddle of oil. looked like mine oil came from drivers valve cover. Started plugging the truck in and Eliminated hard starts no more oil leak. Find my hard start was a glow plug relay. Another time it was the glow plug wiring harnesses and valve cover plugs. I wonder if the cause of our leaks could be when the valve cover plugs get hot and swell the valve cover gasket leaks until it cools. Seemed to only leak during cold hard starts. Fix the hard start problem.
95 f250 supercab stock babied 200k since new several starters, valve cover wiring harnesses fuel pumps, water pumps, many gp relays, glow plugs, new front end, oil cooler gaskets and o rings
billybob20 is offline
post #5 of 5 (permalink) Old 03-25-2006, 09:31 PM
Probably from the external oil cooler. I had the o-rings replaced, there are o-rings that seal the oil from the outside and also seal from the coolant. Mine were brittle and cracked, leaked to the outside. The inside were also hard and brittle, no leak. Hate to think of coolant in the oil or oil in the coolant. Peace of mind is worth a little $$$. [img]/ubbthreads/images/graemlins/smile.gif[/img] [img]/ubbthreads/images/graemlins/smile.gif[/img]
I was only wrong once, that was when I thought I was wrong, but wasn't.
85 F-250 4x4 6.9 Regular cab, 4 spd, flat deck 538 000k, 3.54 gears, making 25.5 MPG Imperial, Racor Water Fuel/separator, original owner.
95 F-350 XL 4x4, 7.3L PowerStroke, 5 spd, 4.10 LS 265/75R16, Regular cab, 246,000 miles, custom box, 12,000 Warn winch, replaced down pipe, home made air intake
72 Mustang Mach 1, original owner, Boss 351, 53,000 miles, estimated 425 HP, all go and still makes 18 MPG
74 F-350, 2x4 390 FE bored to 410, auto, 3.54 gears, 110,000 miles, original owner.
hicom is offline
