Oil Leak coming from under Turbo......... - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-11-2005, 12:20 AM Thread Starter
Well, I have an oil leak coming from under the turbo (I think). I want to make sure I get all the parts I need before I start. The posts I've been reading lead me to think that some pedistal o-rings are needing to be changed. How many are there? Will I need anything else for the job? Thanks
Greg
1994 Ford F-250 4x4, SuperCab, Long Bed, 7.3 PSD, 5spd.Manual,DIY Tymar,Gutted EBPV,Clutch Linkage upgrade(No more Bushing),DPP Down Pipe, Uniden CB with Side band, Napa Perfection Clutch with Single Mass Flywheel, Takonsha Prodigy Brake Controller,175,000 miles and climbing
PowerStroke94 is offline
post #2 of 7 (permalink) Old 08-12-2005, 06:38 PM Thread Starter
Re: Oil Leak coming from under Turbo.........
Is there any where else that the oil could be coming from? It's dripping in the rear of the valley.
post #3 of 7 (permalink) Old 08-12-2005, 07:05 PM
milner351's Avatar
My Photos: (5)
could be one of the oil galley plugs I think, but that would be a fuel leak, which can look like oil with some road grime.... could also be the Epbv rod leaking if it's still intact....
if you need turbo orings, PM me.
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
post #4 of 7 (permalink) Old 08-13-2005, 08:59 PM Thread Starter
Thanks Milner
I picked up the turbo O-Rings from the Stealership the other day. I'm trying to build up the courage to pull the turbo. The EBPV stud seamed dry. Thanks for the reply
Greg
post #5 of 7 (permalink) Old 08-13-2005, 11:56 PM
Are you going to cut the EBPV acuator barrel off while you have the turbo off? Makes putting it back on a lot easier and you will never have an actuator rod leak again!
PM me if you need details on the process or one ready to go.
Rick H...
Pres Omaha Metro PSD Club
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
post #6 of 7 (permalink) Old 08-14-2005, 04:23 PM
Center of the turbo housing cracks.
Don in Austin, Texas '96 F250PSD Crewcab with Byron Eddins custom turbo pedestal, empty EPBV, Wildman chip, Baby Swamp 150cc injectors, Sonnax valve, Byron Eddins intercooler, 3" downpipe, 3xgauges, E40D beefed-up locally.
ISTOCK51 is offline
post #7 of 7 (permalink) Old 08-14-2005, 06:01 PM Thread Starter
Well, pulled the Turbo and changed the O-rings. No oil leak yet. I did gut the EBPV while I was in there. The drivers side rear pedistal bolt was a pain. I had to use a mirror quit a bit. The lower nuts on the collector were also a pain. I didn't have a 15mm crows foot, so I took an old wrench, cut the box end off and welded an old socket to it. Worked like a charm. Thanks for all the replys
Greg
