Oil Leak - Dura Seal Oil Stop Leak - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 03-31-2012, 02:48 PM Thread Starter
We have a 1995 7.3 diesel with 189,000 miles. Thought we had an oil leak so I looked on the forum and noticed one person recommend Dura Seal Oil Stop Leak. After running down the leak we found that it was just a loose fuel filter but we were still interested in knowing more about this product. Looking for feedback would you use it or not?? Thanks
msgift is offline
post #2 of 7 (permalink) Old 03-31-2012, 07:32 PM
blageurt's Avatar
My Photos: (9)
no ...never
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline
post #3 of 7 (permalink) Old 03-31-2012, 08:56 PM
Since Powerstroke injectors are operated using high pressure engine oil, using a product like that could run the risk of seriously damaging the injectors. Plus, I would not count on a product like that actually working.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
post #4 of 7 (permalink) Old 03-31-2012, 09:23 PM
chuckster57's Avatar
I went to their website
And looked. It contains chemicals that cause the seals to swell, like the front and rear main seals. I have had customers ask about using a product like this and my answer is:
It's your choice, A rear main seal is cheap, the labor is what will get you. Bad thing about this kind of product is once the chemicals evaporate, ALL the seals shrink and dry out. then you have to replace all the seals instead of just the original leaker.
Would I use this or any other product like this: NOPE
Train Horns:
PM please not visitor message
chuckster57 is offline
post #5 of 7 (permalink) Old 03-31-2012, 10:02 PM Thread Starter
Thumbs up Thank you
Appreciate your replies...we were surprised when someone had recommended it on another thread.
msgift is offline
post #6 of 7 (permalink) Old 11-30-2012, 05:22 PM
I used Dura Seal oil stop leak on my DuraMax when I was leaking from my main and I mean I was pouring oil!!! I used two bottles and the leak stopped in about 3 days... It's been almost 6 months and it's still good to go... I'd reccomend it to everyone. Good Stuff!
Josh_2009 is offline
post #7 of 7 (permalink) Old 11-30-2012, 05:31 PM
The PSD engine uses injectors that require oil pressure and flow to operate. I think it changed with the 6.4, the Duramax (Isuzu) doesn't use that type of injector, so using a product like described isn't going to have any affect on your fuel system.
Train Horns:
