Oil Pan removal - Diesel Forum - TheDieselStop.com
Old 11-12-2012, 06:47 PM   #1 (permalink)
Oil Pan removal
Is it possible to remove the oil pan with motor in truck? If so, does anyone have a small writeup? Thanks
96 F250 PSD ext cab SB, 5 spd 3'' DP with straight piped exhaust, tymar intake. 150k mi. Dana 60, SD v code springs, RSK
psu927 is offline   Reply With Quote
Old 11-12-2012, 07:14 PM   #2 (permalink)
blageurt's Avatar
My Photos: (9)
No ..... unless you cut the crossmembers and can re-weld them ..........
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 11-12-2012, 07:29 PM   #3 (permalink)
chuckster57's Avatar
I don't think so. Some have removed the cross member to gain access to the pan, but then you have to repair what you did as the cross member isn't bolted in.
Some people have drilled out the rivets, and then replaced with grade 8 bolts. Others have cut the cross member and then welded it back in. FWIW, I would pull the engine for oil pan replacement.
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline   Reply With Quote
Old 11-12-2012, 08:31 PM   #4 (permalink)
klhansen's Avatar
My Photos: (175)
I agree. It's hard enough getting the dang thing off with the engine on a stand. You have to cut the RTV loose by driving a putty knife in the joint after pulling all the bolts. I'd hate to try to do that laying on my back working around crossmembers or even frame rails.
Besides that, you need to have the surfaces spotless before applying the RTV and you have to prevent oil contamination till it cures (24 hrs is recommended). You can't guarantee that when oil is still draining down from the top end of the engine. It should be installed with the engine inverted.
Hard or no-start? Check Here
