Oil pressure gauge - Diesel Forum - TheDieselStop.com
Old 11-02-2009, 05:46 PM   #1 (permalink)
Oil pressure gauge
Hi guys, im a newbie here and this is my first post. I just recently got a 95 powerstroke and love it. I have noticed that it reads low oil pressure on the dash however the truck runs great and does not smoke. From what i've read the gauges on these trucks arent very accurate. I want to put in an afternmarket one, and was wondering if there were any that you guys recomend, or any companies you recomend getting them from. Thanks for the help.
95whitestroke is offline
Old 11-02-2009, 06:09 PM   #2 (permalink)
"Isn't accurate" is an understatement. In actuality it's just a glorified idiot light. The "sender" is actually just a pressure switch. When there's no pressure, the gauge goes all the way down. When pressure comes up, the pressure switch closes, and the gauge just goes...to a position somewhere other than zero.
Although I've added other gauges (boost, pyro) I really gave up on worrying about oil pressure.
'94 F250 supercab 4x4, original owner, 4.10LS, DIY elec fuel, Tymar air intake, Adrenaline HPOP, Beans tunes on 4 position VA chip, VDO gauges (boost,pyro, outside temp), Ford digital AIC, DPPI downpipe, gutted EBPV and turbo pedestal mod, Con OFE clutch, add-a-leafs front and rear, Monroe Reflex shocks, Milemarker 449SS hubs, towing 25' Mallard travel trailer
coming soon: 6.0 IC
nashvillebill is offline
Old 11-02-2009, 06:22 PM   #3 (permalink)
Autometer and Isspro are your common gauges, check out egauges.com.
Welcome to TDS.
BTW, fill out your sig so we can see what you have..it will save time in the future if/when you have a problem.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 11-03-2009, 11:49 AM   #4 (permalink)
Im wanting to add one as well, what psi guage would be needed?? How would someone go about hooking one up. A picture is worth a 1000 words
95 F450 7.3 ZF5 159k 12'PTO Dump, 3"DownPipe,
Tymar Intake & Coolent Filter, SB CON O, DIY Exh Brake.
95 2500 RCLB 251k, HTT 57/65/12, 191 DV, 5x.012 Injectors, 4KGSK, S&B Intake, 5in exh, 33x12.5x17's PC EMT, ProjectorHL w/6k HIDS, Goerend Tripple Disk Auto, 4 Isspro's
BuckshotRam is offline
Old 11-03-2009, 01:14 PM   #5 (permalink)
Something in the 0 to 100 psi range...There is a port on the oil filter housing that can be used for the sender.
I would use an electrical gauge rather than mechanical...last time I used a mechanical oil pressure gauge, the plastic tubing broke and shot oil all over the place.
coming soon: 6.0 IC
Old 11-03-2009, 05:18 PM   #6 (permalink)
Thanks for the information, looks like i got a project for this weekend.
