Oil temp sensor - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 10-30-2005, 10:29 PM Thread Starter
Oil temp sensor
Where is the oil temp sensor and how can it be tested, thanks, Les.
1997 F-350 CC lb XLT 4X4 5spd 4:10,s manual hubs new 255/85/16 Wild Country TXR shoes Westin steps Bilstein shocks Velvet Rides Phantom boost & pyrometer in A pillar water shut-off new fan clutch Tymar intake new IPR new ICP Tymar 4" turbo back exhaust no EBPV no kitty Diesel Power 3 pos flip chip new Valeo clutch @ 109750 Redline MTL & D4 in the bottom BDP Stage 1's valve cover gasgets & glow plugs @ 110650 = pushing Curtis Sno-Pro 3000 & pulling 28' Sierra 5th wheel camper & 18' Sylvan Sportmaster hooked behind camper
6.0 IC next
1994 Ford Ranger (off-road project)
God bless the American Soldier,paying the price for my freedom
Favorite Quote:
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independence. When Firearms go, all go's. We need them every hour!"
US President GEORGE WASHINGTON
BlueDeuce is offline
post #2 of 6 (permalink) Old 10-30-2005, 11:13 PM
Re: Oil temp sensor
I believe the oil temp sensor is located on top of the High Pressure Oil Pump Resivoir, I'm not 100% sure though.
Smokyred- RED 11/97 F250HD XLT SCLB Auto 4.10LS 4x4 OFFROAD
Mods: Swamps tunes, Swamps 275/226's, a Gen3, a BTS, Comps, Crowers and H11's up top, S465/TN II mount kit, Custom Comp. fuel system, and an IC.
smokyred is offline
post #3 of 6 (permalink) Old 10-31-2005, 08:09 PM Thread Starter
Re: Oil temp sensor
anyone else, could this cause an idle problem????? Thanks, Les. [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img]
6.0 IC next
Favorite Quote:
post #4 of 6 (permalink) Old 10-31-2005, 08:37 PM
Re: Oil temp sensor
BlueDeuce,
The EOT is on the backside of the HPOP reservoir, actually, a little ways down from the top. Drain the HPOP oil until it's below the sensor, unplug the sensor and remove it w/ a 1" socket (if I remember right). Replace w/ new EOT, reconnect, refill HPOP reservoir and you're good to go.
My limited experience is that a bad EOT can cause a poor idle. Mine got to idling fairly roughly; a new EOT ($15 from IH) smoothed it out. Smoothed it out at all RPM's and loads, actually.
good luck
95 F250 XL, 2WD, RC, LWB, PSD, MT, 3.55 open
Purchased new; 180k miles; stock except: coolant filter, real flywheel & clutch, GPR
strangwz is offline
post #5 of 6 (permalink) Old 10-31-2005, 09:34 PM Thread Starter
Re: Oil temp sensor
Thanks wreckingball, it's worth a shot [img]/ubbthreads/images/graemlins/confused.gif[/img]
6.0 IC next
Favorite Quote:
post #6 of 6 (permalink) Old 11-01-2005, 09:43 AM
Re: Oil temp sensor
BlueDeuce,
Let us know how it goes. So many factors play into idle quality; it looks like you've already fixed a couple: IPR & ICP.
Bill
strangwz is offline
