OK I am stumped, (Not stumped any more) - Diesel Forum - TheDieselStop.com
Old 05-22-2005, 09:02 PM   #1 (permalink)
RSP
My Photos: (17)
I am putting my other 97 togather and I have no Fuel pedal anything. It takes a while to start and when it does it idles fine sometimes with a CEL and sometimes not and Never does the Pedal work. I hooked up my Auto Enginuity and set it to monitor Throttle position and IVS. When I push the Pedal the IVS goes to a 1 in Red and the TPS goes from a Red 99 to a Red 100. I take it the Red is Negative correct? I thought it was the TPS but i took one out of a 99 Parts truck and didnt make a drop of difference. Now I have, Put a complete 95 Engine with Harness in this 97 so Is there a problem with the 95 harness working in the 97? Everything else seems to work fine.
The Code it set is Fuel& Air Metering/ P0123 Throttle/Pedal position Sensor/switch A Circut High Input???? I ran the KOER test and it reved up ok. I am Stumped.
2006 F250 CrewCab Lariat FX4 6.OH AFE, MBRP SS Cool Duals, Elite SCT, 4 Up the pillar, Bed Rug and Retrax Lockable cover.
1997 F350 CrewCab XLT 4x4. ?hp/?lb-ft Intercooled, BTS Trans, BTS Dual HPOP, Big Full Force Diesel Jectors, Big Turbo, Ford AIC, Rockin S Custom 5 inch Exhaust w/AeroTurbine Muffler, AFE Stage II Intake, Total Diesel Performance 4 Positon Chip, White Face Gauges,
1979 F250 SC Lariat 4X4 5.9 CTD, BTS E40D, Dana 60/Sterling 10.25, SD HydroBoost brakes, 440HP 992lb-ft, Intercooled, BFG All Terrains on Eagle Alloy 102s. Custom Rockin S Dual stack Exhaust system. DDP Stage IV injectors, HTB2 Turbo, Snow Water/Meth injection
My Webshots page
RSP is offline
Old 05-22-2005, 11:04 PM   #2 (permalink)
Tom S's Avatar
My Photos: (20)
Re: OK I am stumped
RSP something seems to click in my brain that the OBS use a different pedal assembly than the newer trucks. Have you tried swapping in a known good unit like for a like hear truck. Without looking I would think the pedal communicates directly to the PCM. If a known good pedal does not fix it I would start looking for a source along the route of those wires. You might also want to see how the scan tool behaves on a a truck that is running right. I looked at that once on mine but cannot remember just how it works.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood, 14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 05-22-2005, 11:13 PM   #3 (permalink)
RSP
My Photos: (17)
Re: OK I am stumped
Well I am thinkig about yanking the one outta my other 97 but am a litte scared to mess with it. I Dont think its the pedal since I have replaced the TPS and checked the IVS and it works just like the 99 one does. Wires in the truck all look brand new, Truck only has 100,000 miles on it and Most everything under the dash looks like it was new yesterday.
My Webshots page
RSP is offline
Old 05-23-2005, 12:41 AM   #4 (permalink)
RSP
My Photos: (17)
Re: OK I am stumped
Maybe I should have asked Why Tymar Performance Doesnt have a Web site. Man this site has gotten bad. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
My Webshots page
RSP is offline
Old 05-23-2005, 04:07 AM   #5 (permalink)
Re: OK I am stumped
the cicuit high input makes me think one of two things:
1. the ivs is not closing when the throttle is depressed
2. the tps is not returning to idle or getting voltage
get a voltmeter and check the bottom wire on the tps, it should have 5 volts. then check the resistance between the other two posts ON the tps, they should change their resistance as the throttle is depressed (i dont remember exact numbers sorry). if that all checks out move to the ivs, one terminal should have 12 volts and the other one should get 12 volts once the pedal is pushed far enough to make it click.
TPS
pin # 1 resistance varies to pin 2 ( ohm meter one lead here one on pin 2)
....... 2
....... 3 5 volts
IVS
pin # 1. 12 volts with pedal depressed
.......2. 12 volts constantly
hope this helps, [img]/ubbthreads/images/graemlins/shrug.gif[/img] good luck
96 cc f-350 4x4 Auto 305k d/p,straightpipe,chip,diy tymar
97 f-350 4x4 reg cab 5 sp, d/p and 4in exhaust, afe, ts 6 pos chip
oregon96psd is offline
Old 05-23-2005, 12:35 PM   #6 (permalink)
Re: OK I am stumped
I'm betting its the IVS, had the same problem (would idle fire but when the pedal was pushed I got a CEL and thats it). All you have to do to check it is ohm it.
Partsman is offline
Old 05-23-2005, 01:46 PM   #7 (permalink)
RIP
Re: OK I am stumped
Guys, I'm having problems, again, with my pedal assembly cutting out, giving me a CEL, and causing the limp-home shifting. BUT, I just found an assembly out of a wrecked truck here locally for $20. You might want to call around to salvage yards and pick up a cheap one...sure beats $300 and you can't lose much. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
MINE: '02 F250 4x4 CC SWB 7.3L PSD, 130k, 4" downpipe and straight exhaust, open-element Amsoil Eaa, Baldwin by-pass filter, 48 gal aux. tank, SCMT 1705 (Tow Safe Level)
WIFE'S NEW: '06 Dodge Ram 2500 SLT Quad 4x4, Cummins 5.9L
[color:"red"] FIGHTIN' TEXAS AGGIE CLASS OF '92 [/color]
RIP is offline
Old 05-23-2005, 06:18 PM   #8 (permalink)
RSP
My Photos: (17)
Re: OK I am stumped
Ok I have tried 2 other pedals and the same thing, CEL, and overdrive light flashing and no go. I have no clue, I have checked everything I know of.
My Webshots page
RSP is offline
Old 05-23-2005, 08:12 PM   #9 (permalink)
Re: OK I am stumped
Man, does this sound familiar. The 95 and 97 use different harnesses. I don't know how much of the 95 harness you used, but they are definitely different at the firewall plug. I think the first thing I would do is install the 97 harness, and your problems will probably go away.
Tim
"Better to be hated for who you are, than loved for who you're not." - Van Zant
My Truck 1972 F-350 4x4 Extended cab 14-36 Swampers, 97 Powerstroke, 4 position chip with custom tunes, 3" downpipe, 5" exhaust, 99 intercooler, DIY E-fuel, Dana 60 front, 70 rear, lockers in both ends.
<font color="blue">72 POWER STROKE</font> <font color="red"> INTERIOR PICTURE </font> <font color="blue"> ENGINE PICTURE </font>
Wifes' Grocery Getter 99 F-250 SD 4x4 XLT Lariat 4 door. 7.3, Auto, 4 pos Bullydog chip, 3 1/2" downpipe, 5" straightpipe, Genuine Tymar, Stage 1 Monsterbox, 33-12.50-16.5's
72Pstroke is offline
Old 05-23-2005, 08:38 PM   #10 (permalink)
RSP
My Photos: (17)
Re: OK I am stumped
Yep I wish you would have posted yesterday, Thats what it was one Freakin Wire, It was one Black/white wire from the Firewall plug to the Computer, I drilled the holes out of the Plugs and installed that wire and it started working great. Now what else am I gonna run into [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
My Webshots page
RSP is offline
Old 05-23-2005, 11:44 PM   #11 (permalink)
Tom S's Avatar
My Photos: (20)
Re: OK I am stumped
Are you saying it is the 104 PIN connector that hooks to the PCM? Does this mean the PCM will not interchange from a 95 to a 97? I am glad that you figured it out though.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
Old 05-23-2005, 11:46 PM   #12 (permalink)
Re: OK I am stumped
The PCM connector is the same. The connector where the wiring harness passes through the firewall is different between 95 and 97. The locations of some of the wires are different.
Tim
Old 05-24-2005, 12:47 AM   #13 (permalink)
RSP
My Photos: (17)
Re: OK I am stumped
I took the wire out of the firewall Connector and the PCM connector and installed it in the proper places on the Harness Plugs. As soon as I turned the key I knew it was fixed. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Just to Verifi This harness was NOT a 95 it was from a 97 that was built in 96. The Engine harness is a 95. The truck Im working on is a Mid year 97.
My Webshots page
RSP is offline
Old 05-24-2005, 07:39 PM   #14 (permalink)
Tom S's Avatar
My Photos: (20)
Re: OK I am stumped
I guess I am not understanding which connector you guys are talking about.
Tom
96 F250SC 4X4 AUTO
Tom S is offline
Old 05-24-2005, 08:21 PM   #15 (permalink)
Re: OK I am stumped
Tom, the connector I am talking about is the main connector that goes through the firwall. It feeds the engine and everything on the front of the truck. Ford refers to it as C202, I believe. There is a second, smaller harness that feeds the rear of the truck. The C202 is different between 95, 96, and 97.
Tim
