oops #2 - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 12:08 PM   #16 (permalink)
Here is the check valve ball.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 11-03-2009, 01:22 PM   #17 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
I recant my earlier statement that I did not have the ball in there. I just took apart the old one and low and behold there it was way inside the opening in the regulator.
Buckshot check your inbox.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-03-2009, 07:23 PM   #18 (permalink)
pjwoolw's Avatar
My Photos: (5)
If your going to go through the bowl here is a great kit. That Ford part isn't worth the money. There is nothing to wear out in the FPR. Use the o ring from the kit above and a BB if you wish on reassembly.
Your bowl is a bit different from mine. Powerstrokeshop has a good illustration that shows the differences. Mine has another metal screen. Yours wont.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-03-2009, 11:44 PM   #19 (permalink)
Thankyou Thankyou
95 F450 7.3 ZF5 159k 12'PTO Dump, 3"DownPipe,
Tymar Intake & Coolent Filter, SB CON O, DIY Exh Brake.
95 2500 RCLB 251k, HTT 57/65/12, 191 DV, 5x.012 Injectors, 4KGSK, S&B Intake, 5in exh, 33x12.5x17's PC EMT, ProjectorHL w/6k HIDS, Goerend Tripple Disk Auto, 4 Isspro's
BuckshotRam is offline
Old 11-04-2009, 12:42 AM   #20 (permalink)
Speaking of powerstrokeshop...when did they change the make model breakdown for the OBS and superduty quick parts section?
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-04-2009, 12:59 AM   #21 (permalink)
pjwoolw's Avatar
My Photos: (5)
Not sure. Caught me by surprise a few weeks back. LOL I thought I just never noticed before.
Pete in San Ramon
pjwoolw is offline
Old 11-04-2009, 01:02 AM   #22 (permalink)
I was just on there last week and they still had the 94-97 and 98-03 or whatever it was still on there. It sucks because you could look up just about anything and get a diagram for it but not now.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
