Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 09-28-2007, 11:19 PM   #46 (permalink)
My Photos: (13)
Re: P1211 not due to being chipped??
Sounds like the screen in the HPOP is clogged. [img]/forums/images/%%GRAEMLIN_URL%%/mad.gif[/img]
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is online now
Old 09-28-2007, 11:32 PM   #47 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Also why is my analog gauge still showing high pressure and rising but the AE showing 724psi? </div></div>
The pressure shown through AE or any other scan tool is a computed value given by the PCM, so it is not what the PCM may use for engine control strategy, whereas ICP V will be the exact reading from the ICP Sensor, if the PCM is detecting unusual ICP values, it will default to a programmed strategy and ignore the input from the ICP. From looking at your chart, the ICPV is showing the same reading as what your gauge would show, but the PCM doesn't like it, so it is inferring its own value. Watching ICP instead of ICPV can easily mislead someone sometimes.
If the engine will start and run with the IPR unplugged, either you have a faulty new IPR, or something downstream, or just upstream of the IPR may be plugged or restricted. What is the oil quality like? When you removed/replaced the IPR previously, was there any signs of debris in the IPR to indicate a potentional HPOP failure, which could have damaged the new IPR?
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 09-30-2007, 03:07 PM   #48 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Buddy_M</div><div class="ubbcode-body"> <div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body">Also why is my analog gauge still showing high pressure and rising but the AE showing 724psi? </div></div>
</div></div>
Oil had 2600 miles on it when this problem occured, I changed oil before the troubleshooting stage mainly because it was due. No debris in the old IPR looked very clean.
&lt;&gt;&lt;
1996 F350 PSD, CC, DRW, 2WD, Custom conversion, 3" downpipe, BDP stage 1 injectors, BDP 6 pos chip. Autometer gauges. Electric fuel system. CONVERTED to run on Veggie FN74 system modified.
2003 Toyota Matrix
2001 VW NewBeetle GSL TDI
1954 GMC 5 window pickup. in the rebuilding stage, it might even get a DIESEL
KansasDiesel is offline
Old 09-30-2007, 11:03 PM   #49 (permalink)
johndeerebones's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: KansasDiesel</div><div class="ubbcode-body">JDBones - Action and I have discussed that T/S too that a restriction could be my problem, but from what I understand is that there isn't anything but to replace the HPOP. That's an expensive Guess. Or is the restriction in the resivour? They are seperate from what I gather. Is there NO WAY POSSIBLE to clean out the Resv? even if you remove it from the engine? </div></div>
Has to be a return issue, yes, your hpop could be stopped up, but I belive the after the return oil flows like this...
pressure to ipr - lets excess through which goes back through the hpop and gasket to the front cover - then either to the resevoir or to the pan, can't remeber where it goes from there....
might take the hpop off and fish a small diameter cable through the return galleies and make sure they are clear....
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 10-03-2007, 10:40 AM   #50 (permalink)
Here is my current update, I did remove the HPOP and did my best to clean it out, I did get some debris out of the pump some metal shavings. Put it back on the engine and gave her a try, for troubleshooting. The pressures were on the avg 400psi lower at idle then they were the previous runs, but still in the 900 psi range. then the CEL came on and rough idle again. The next run seemed even higher pressure. This to me indicated the HPOP is getting clogged with some sort of debris causing the high pressure at idle.
Side note: I find it funny that I wish I had this higher pressure when running the higher RPMS. but can't live with the CEL and the rough idle, I can get 4000psi easy right now. :-)
Where can I get a HPOP the least expensive?? Anyone have a source? I need one rather Quickly!
&lt;&gt;&lt;
2003 Toyota Matrix
Old 10-03-2007, 10:46 AM   #51 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: KansasDiesel</div><div class="ubbcode-body">Here is my current update, I did remove the HPOP and did my best to clean it out, I did get some debris out of the pump some metal shavings. Put it back on the engine and gave her a try, for troubleshooting. The pressures were on the avg 400psi lower at idle then they were the previous runs, but still in the 900 psi range. then the CEL came on and rough idle again. The next run seemed even higher pressure. This to me indicated the HPOP is getting clogged with some sort of debris causing the high pressure at idle.
Where can I get a HPOP the least expensive?? Anyone have a source? I need one rather Quickly! </div></div>
You can usually buy a stock hpop for our trucks on ebay, there is always one being parted out.
I would take this opotunity to upgrade to the 17* crm pump though....
My Pics
Old 10-03-2007, 10:50 AM   #52 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: johndeerebones</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: KansasDiesel</div><div class="ubbcode-body">Here is my current update, I did remove the HPOP and did my best to clean it out, I did get some debris out of the pump some metal shavings. Put it back on the engine and gave her a try, for troubleshooting. The pressures were on the avg 400psi lower at idle then they were the previous runs, but still in the 900 psi range. then the CEL came on and rough idle again. The next run seemed even higher pressure. This to me indicated the HPOP is getting clogged with some sort of debris causing the high pressure at idle.
I would take this opotunity to upgrade to the 17* crm pump though.... </div></div>
I was wondering if the 17* pump would work. I looked on Ebay last night and didn't get any coming up. I don't mind spending a little extra but can't swing it from Ford or International. I would also like one with a warrenty. So it would have to come from a reptubale company
&lt;&gt;&lt;
2003 Toyota Matrix
Old 10-03-2007, 11:06 AM   #53 (permalink)
My Photos: (13)
Get the 17* pump.
Only change will be the hose connections on the pump.
Bill
Old 10-03-2007, 11:12 AM   #54 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: MADVAN</div><div class="ubbcode-body">Get the 17* pump.
Bill </div></div>
Thanks Bill, do you have a source for an inexpensive pump?
&lt;&gt;&lt;
2003 Toyota Matrix
Old 10-03-2007, 11:14 AM   #55 (permalink)
The 17* pump was on what years?
&lt;&gt;&lt;
2003 Toyota Matrix
Old 10-03-2007, 11:37 AM   #56 (permalink)
My Photos: (13)
17* is 99 and up SD.
Most available is reman. Really have never seen new.
As stated above sometimes Flea-bay for good price.
Bill
Old 10-03-2007, 11:50 AM   #57 (permalink)
Yep, not looking for new Reman. is good enough for me. Ebay has nothing, Just tying to find a good price out there. And having a hard time even finding them.
&lt;&gt;&lt;
2003 Toyota Matrix
Old 10-03-2007, 12:02 PM   #58 (permalink)
My Photos: (13)
If all fails IH is less than ford. Just donot let them know the core is a 15*.
Check your local parts guy. Might not be to bad.
Bill
Old 10-03-2007, 08:59 PM   #59 (permalink)
Ed... do us all a favor .....When you get the new pump, tear the old one apart & take some pictures of the elusive "edge " filter
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 10-03-2007, 09:00 PM   #60 (permalink)
Did you have any luck on car part?....
Rick.....
