Parts # help - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-23-2009, 06:45 PM Thread Starter
zombietroopers's Avatar
Parts # help
Does anyone have the parts numbers for basically the turbo back. What I am after is the y-pipe and pipes down to the manifolds. I would also need all the packings and turbo gasket numbers.
Any info would be appreciated.
97 F-250 HD 7.3 L
1997 F-250 HD,5-Speed,4X4,Ext/cab,393,000 km 3" Turbo downpipe with 4" exhaust, No Cat,Firestone rear airbags,255/85/16 Toyo
M-55 tires,new transmission HD upgrade
Luk clutch/flywheel single mass conversion,Drawtight front hitch,Class 5 Hidden Hitch,Tekonsha brake controller,Warn 6000lbs.winch on custom removable plate,Tymar coolant filter kit,coolant eye,Tymar HPX kit,K/N cone air filter (open air),Shimmed FPR,SCMT 1705,Autometer boost gauge,Autometer pyrometer,SP Diesel EBPV dongle,Ford auxillary idle control.3 Electric cooling fans,gutted EBPV
zombietroopers is offline
post #2 of 3 (permalink) Old 12-23-2009, 08:09 PM
DaveBey's Avatar
My Photos: (203)
zombietroopers -- Hope this helps!
Scroll down and open the attachment in a new window.
These are all from my 1997 Ford Light Truck Master Parts Catalog so please verify before purchasing anything.
All listings follow:
Model/Restrictions | Part No. | Description | Qty.
6N632 FLANGE (ENGINE CHARGE EXHAUST)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6N632-A | This flange attaches 6K854 pipe to turbo inlet Y (This is used on both L.H. & R.H. pipes at Y connector end of turbo | 2
6N639 OIL (DRAIN TURBO MOUNT)
F250, F350, F(Super Duty) --DI turbo M/T | F4TZ-6N639-A | This part sits under turbo and holds it to engine(Bolts that hold the turbo to the pedestal F5TZ-9G486-AA need to be order separately. Also 6C673 comes with 6N639) | 1
F250, F350, F(Super Duty) --DI turbo M/T & A/T | F4TZ-6N639-A | This part sits under turbo and holds it to engine(Bolts that hold the turbo to the pedestal F5TZ-9G486-AA need to be order separately. Also 6C673 comes with 6N639) | 1
6A640 DUCT (ADAPTER TURBO INLET)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6A640-A | | 1
6C640 TURBO (INTAKE HOSE)
F250, F350, F(Super Duty) --DI turbo | F6TZ-6C640-A | This attaches the turbo air to intake man. (2 needed) | 2
6N640 EXHAUST GASKET (INLET)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6N640-B | This gasket mounts under the turbocharger on exhaust | 1
6N646 PIPE ASY (ENGINE EXHAUST
F250, F350, F(Super Duty) --DI turbo | F4TZ-6N646-B | Mounts from turbo output to cat.conv. | 1
6N653 O-RING (OIL DRAIN)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6N653-A | Mounts on top and below turbo pedestal 1 used on top 1 used on bottom of pedestal | 2
F250, F350, F(Super Duty) --DI turbo | F4TZ-6N653-B | Mounts on top and below turbo pedestal 1 used on top 1 used on bottom of pedestal | 2
6C673 SOLENOID KIT (BACK PRESSURE SOLENOID
F250, F350, F(Super Duty) | F5TZ-6C673-A | This part fits on the turbo and has two wires coming off of it (also is incl. in 6K682 asy.) | 1
6K682 TURBO-CHARGER ASY.
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K682-BRM | #1822869-C91 Incls. pedestal asy. and turbo | 1
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K682-BRM | #1822869-C92 Incls.pedestal and turbo | 1
F250, F350, F(Super Duty) --DI turbo | F6TZ-6K682-ARM | #1822775-C92 Excls.mounting pedestal | 1
6N696 TUBE ASY.(TURBO CHARGE TO INTAKE MANIFOLD
F250, F350, F(Super Duty) --DI turbo | F5TZ-6N696-AA | #1822785 New reman part | 1
6K854 TURBO INLET PIPE
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K854-A | L.H. exhaust pipe from exhaust man to inlet to turbo Y (comes with flange to mount to exhaust man.) | 1
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K854-C | This is the seal to seal the flange to the Y at turbo inlet (used on both L.H. & R.H. pipes at Y connector at turbo end) | 2
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K854-D | This is the Y connector that mounts to the turbo W/4 bolts | 1
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K854-E | R.H. exhaust pipe from exhaust man. to inlet to turbo Y | 1
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K854-F | This is a R.H. flange used to mount pipe to exhaust man. | 1
F250, F350, F(Super Duty) --DI turbo | F6TZ-6K854-A | This tube inlet R.H | 1
6K864 BRACKET (TURBO AIR INLET)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K864-A | Supports inlet duct mounts on valve cover | 1
6K889 DUCT (Y INTAKE MANIFOLD)
F250, F350, F(Super Duty) --DI turbo | F4TZ-6K889-A | This Y pipe comes off the pressure side of turbo and mounts to L.H. and R.H. intake man | 1
F250, F350, F(Super Duty) --DI turbo | F6TZ-6K889-A | This the Y tube to intake man. | 2
8287 CLAMP (HOSE)
F350 | 8 Cyl. 7.3 | F3TZ-8287-A | | 1
F350 | 8 Cyl. 7.3 | F4TZ-8287-B | Clamp at Turbo | 1
For the base part numbers begining with 9, check out my old Big Ford Fuel-Related Part Numbers Post post.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4
-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●APCM
250,000 happy miles
DZLJIM 3:16
- Hold my beer and watch this.~~
DaveBey is offline
post #3 of 3 (permalink) Old 12-23-2009, 08:40 PM Thread Starter
Thanks I will double check everything.
