PCM, ECM, or ECU replacement - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 09-22-2006, 04:51 PM Thread Starter
I'm replacing the ECM in my 97 F350 powerstroke automatic. Tried to buy a replacement from one dealer and they said they have to do it because they have to download the program from my old ECM and load it onto the new one. Called another dealer and they said that is not true. That Ford sends them out with the basic program and you just have to bring it in to get any updates from Ford. Called a mechanic I knew and he said that it does come programmed but may not be exact to your engine transmission match and so it might run or might not.
Anyone know which story it true?
CDMF350 is offline
post #2 of 8 (permalink) Old 09-22-2006, 05:17 PM
Tom S's Avatar
My Photos: (20)
Re: PCM, ECM, or ECU replacement
Jody aka DP Tuner can reflash your PCM with the code you would need or even a performance tune in there if that helps any. I saw a TDE0 pcm on ebay I think just the other day for a decent price.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood,
PMF RSK V and B code springs
Tom S is offline
post #3 of 8 (permalink) Old 09-22-2006, 05:34 PM
PSDfreak's Avatar
You can get them at autozone for around $200 too...
Good Luck,
Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #4 of 8 (permalink) Old 09-22-2006, 08:09 PM
Nit
first, why do you think you need to replace it? msot times when teh scanner or books say replace PCM, is because they don't know what the actual cause is. usually it works / don't work. You can order the PCM code you wish , a TED0 or TED1 is what programmers usually use to base their stuff on for autos.
Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now
2004 Dodge 3500 twin turbo 525hp rocket
Nit is offline
post #5 of 8 (permalink) Old 09-22-2006, 10:02 PM Thread Starter
Thanks for all the reply's,
Dealer diagnosed it as needing replaced because the tranny would not shift into overdrive (see posting entitled Powertrain control module from last weekend).
Question was because of the many different stories I was getting as I called around to see what I could get one for.
I ended up buying one this afternoon, I put it in, plugged it in and the truck ran fine so I guess the story that it was plug and play was correct. That dealer did tell me that I would have to bring it in to get any update that the Ford may have put out.
Once again, thanks.
CDMF350 is offline
post #6 of 8 (permalink) Old 09-23-2006, 01:01 PM
Once again, thanks.
Yeah right, if they don't know if there is an update or not, I would not bring it in just to find out. They should already know if there is or isn't one. $$$$$$tealer$hip!
2003 F350 crew cab 4x4 , 295's on 17's, performance MFG coolant filer, Blue spring, new HFCM, FICM, Batteries and Alt. SCT performance tune, 128k on engine 12/13. Stock everything else.
ryhed is offline
post #7 of 8 (permalink) Old 09-26-2006, 03:17 PM
What's the best way to tell if it needs updating, for those of us who have bought used trucks?
Thanks,
Michael
1997 F250 4x4, E40D, 285x75x16's, long bed, supercab, 155K, stock... for now.
mrstang01 is offline
post #8 of 8 (permalink) Old 09-26-2006, 11:17 PM
My Photos: (11)
My advice is to not allow the dealer to "upgrade" the programming. You might not like what you get (BTDT) and you can't go back. Instead spend the money on a good chip with the programming you want. There can be more than higher power in a chip.
2010 Ram 3500 Cummins, AT, 4x4, CC, LB, Line-X, B&W Turn Over Ball, RBW Lil Rocker modified to fit B&W, Milemarker hyd. winch.
9VS slide-in,
24 ft. fifth/w slide, Century topper, old classic Sooner 18' 4 horse stock trailer. StarFlyte by DynaMax 6.8 V10
Formerly:
SC LB PSD. 4x4, With lots of Goodies. Twas a good truck.
If you don't care where you are, you ain't lost.
Larry
Larry S. is offline
