PCM p/n HELP! - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-21-2005, 08:49 AM Thread Starter
PCM p/n HELP!
I need to buy a new/used PCM for my truck. I'm at work and do not know it's p/n.
What do I need to know to buy one?
Will any year 1994-1997 with an automatic work?
Mine was a NAW4 flash, do I need the exact same?
I hope to still be using a chip, so if the truck will run, the flash doesn't matter, right?
Thanks guys!
1996 F250 Extended Cab, E4OD, 3.55's, Long Box, 4X4. Western Unimount Snow Plow, Tuff Counrty 4" lift, Front reciever hitch, Factory style Running Boards ('til they're torn off...) Tymar, DPP Downpipe, Lost Kitty, Pedal Mod, Shimmed Regulator, Sonnex valve, Tri springs. 107,000 miles and counting....Bill's Race 4 bank chip, Auto meter 'Z's in a piller pod, 4" full exhaust, tank mod's, looking for a Bronco tank, need a locker in the rear......
jeffcoll is offline
post #2 of 7 (permalink) Old 11-21-2005, 08:54 AM
Re: PCM p/n HELP!
have you tried joat's part page????????
if its not on here i dont know it.
RYAN
GAUGES, INTAKE, EXHUAST, SBC CLUTCH, CHIP, BDP INJECTORS, BILSTEINS, BUSHINGS...AND A WHOLE LOT MORE..
B99 BIO DIESEL SUPPORTING AMERICAS FARMERS.
US NAVY
looking for an ext cab 4x4 short bed DURAMAX!!! keeping the obs of course.
1997PSD4ME is offline
post #3 of 7 (permalink) Old 11-21-2005, 09:10 AM
Re: PCM p/n HELP!
here are the numbers 6-90A / DPC-202 / F6TF-AYE , not sure which of these numbers you will need.
1995 f250 XL Ext Cab 4x4, auto ,3.55 gears , 317,000 miles , K&N filter , muffler Deleted ,Shimmed FPR, hypertech chip (a basic older one of unknown power) ,boost guage , small amount of leaf spring work done rest of is stock , steel wheels with hub caps , carpet delete. My old user name was Daveuz , UPDATE AS OF 11/05 new starter new waterpump LEFT ENGINE FAN OFF, new IPR new CPS replaced injector drive (used) all new under the cover harnessess and GPs and all this and my stalling problem was fixed by replacing the PCM , which I had DP Tuner flash in the 80hp econo. 12/28/05 cleaned the Cat Box UPDATE 12/06 334,000K NEW NEW NEW 11/06 1997 xlt CC LB 4x4 all white with a with topper. 285K all stock.
daveUza is offline
post #4 of 7 (permalink) Old 11-21-2005, 09:14 AM
DaveBey's Avatar
My Photos: (203)
Re: PCM p/n HELP!
jeffcoll -- If you can, get a PCM with a TDEx calibration. The transmission shifting strategy is muuuch better than the NAWx calibrations.
The part number for NAW4 is F6TZ-12A650-AYE.
The part number for TDE0 is F7TZ-12A650-TA.
The part number for TDE1 is F7TZ-12A650-TB.
Not sure if you can still get the NAW4 or TDE0 though. Powerstrokeshop.com has the TDE1 in stock for a little less than $275.00.
Cheers from Orlando, FL! [img]/ubbthreads/images/graemlins/smile.gif[/img]
Dave
1996 F-350 XLT CC SRW 4x4
-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●APCM
250,000 happy miles
DZLJIM 3:16
- Hold my beer and watch this.~~
DaveBey is offline
post #5 of 7 (permalink) Old 11-21-2005, 09:45 AM
Re: PCM p/n HELP!
You can't use a 94 PCM, and don't use a 95. 94's dont have auto tranny's. 95 the OBD-II port is not enabled but a chip may fix that. You have to use a PCM flashed for an auto tranny.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #6 of 7 (permalink) Old 11-21-2005, 09:57 AM Thread Starter
Re: PCM p/n HELP!
Thanks alot for the fast response guys!
I think I'll go TDE1. I get good prices from NAPA, and I see they list this part online, I'll call and get a p&d from them first.
Thanks again!
jeffcoll is offline
post #7 of 7 (permalink) Old 11-21-2005, 10:58 AM
Re: PCM p/n HELP!
I like the TDE1 code.
