pinion nut size - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 12-01-2006, 01:25 PM Thread Starter
pinion nut size
I just snapped the yoke on the rear diff. and I'm stuck at work. Does anyone know what size the nut is as it looks like I'll have to run out and buy one.
10.25 sterling ltd slip
thanks
04 f350 ext cab 4x
95 psd 4x,5sp, down piped, 10,000lb warn, hydro bumper,tymar type intake, 285/75/16 at2 yoki geolanders, custom boat rack with 12' aluminium on top, kawi kdx in the box,
fastford is offline
post #2 of 5 (permalink) Old 12-01-2006, 06:42 PM
Re: pinion nut size
1-1/8" if i remember right. it has been a while. either that or 1-1/16".
you have to get the thin walled socket though, the thicker ones wont fit b/c the nut and the hole of the yoke
-cutts-
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
post #3 of 5 (permalink) Old 12-01-2006, 07:01 PM
pschand's Avatar
Re: pinion nut size
Why do you need a new nut? If the yoke broke, the nut should be able to still be used. I used a 1 1/16" I think and my socket was not a thin wall and it worked just fine. You might need a breaker bar with a cheater if it has been on there from the factory. It's tight!! [img]/ubbthreads/images/graemlins/shocked.gif[/img]
06/F350/6.0L/CC/4x4/LWB/AT/SCT XCAL2
pschand is offline
post #4 of 5 (permalink) Old 12-01-2006, 09:21 PM
BlueMule's Avatar
My Photos: (12)
Re: pinion nut size
They way I understood it he was going to buy a new yoke and need the nut size so he could get the right size wrench to r and r the yoke.
Rodney#33
BlueMule is offline
post #5 of 5 (permalink) Old 12-01-2006, 10:20 PM Thread Starter
Re: pinion nut size
It was 1 1/8th. It was pretty tuff going on. Went on a bit easier after warming it up and smacking it with the the 5lb sledge. Of course there was a piece of wood between the sledge and the yoke. I'm finding the driveline on this truck is leaving much to be desired.
So far I've replaced both yokes, rebuilt the 5spd, replaced all the ujoints everywhere some a few times and now the front driveshft has developed considerable slop in the slip joint section.
I hope at least thats the last time I drop a shaft in the middle of an intersection with an on coming gravel truck lined up to the drivers door.
thanks
04 f350 ext cab 4x
fastford is offline
