Plugged in white smoke - Diesel Forum - TheDieselStop.com
Old 01-23-2013, 04:58 AM   #1 (permalink)
FordFisherman's Avatar
My Photos: (5)
Been pretty cold here for the past few days. Have the truck plugged in on a timer. After sitting for a day when I start it there is alot of white smoke. GPR is new. When not plugged in above 20 degrees I get minimal smoke if any. Any ideas?
96 F350XLT 4x4 Auto 7.3 Straight 3.5 exhaust 3:55
DIY Intake, 3" downpipe, SCT tuner, Pyro Boost Trans Gauges-Front add-a leafs, Dieselsite Coolant Filter-245,000mi.
FordFisherman is offline   Reply With Quote
Old 01-23-2013, 08:43 AM   #2 (permalink)
Sounds like your plug has a broken wire and is not working. You could have 1 or 2 glow plugs that are not working also.
Dave
1997 F-250HD XL 4x4 regular cab, toreador red with matching cap. Tymar intake ,HPX and coolant filter, B+M trans pan and a lost kitty. 3" ss downpipe. Stancor, 4:10 gears Amsoil in engine. 225K, E40D auto. Cruise control mod. DB starter(rebuilt after 13 months). AIC. Ford reman tranny at 195k.
2011 F350 CrewCab, Black, 6.7, Rhino Lined, Delta Pro Crossbed toolbox and a whole bunch of other crap.
bluefin is offline   Reply With Quote
Old 01-23-2013, 09:28 AM   #3 (permalink)
blageurt's Avatar
My Photos: (9)
If you put your ear on the hood you should be able to hear the block heater working.....If not check the plug as they usually cook first....
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 01-23-2013, 10:16 AM   #4 (permalink)
Depending on background noise you should hear the heater perking away right above the left frt tire if it's working right. That's where you're closest to the heater from outside the truck.
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline   Reply With Quote
Old 01-23-2013, 12:19 PM   #5 (permalink)
My Photos: (5)
Yup, she's perkelating. Fires off after two seconds but still seems like alot of smoke for being plugged in.
Old 01-23-2013, 03:57 PM   #6 (permalink)
I get smoke from mine too, so does my buddy.. seems to be "normal" on these trucks when it's cold. It usually just smokes until it warms up.
95 7.3, 5spd Manual (197k)
4x4, Cherry Red, Ex Cab long box
Dual 16gal tanks
3'' turbo back strait pipe
2.8'' leveling kit
28.5 Toyo MT
delta7503 is offline   Reply With Quote
Old 01-23-2013, 04:08 PM   #7 (permalink)
My Photos: (5)
ok, thanks.
Old 01-24-2013, 09:02 AM   #8 (permalink)
Being plugged in doesn't warm up the incoming air charge or warm the entire block. Cold air leads to incomplete combustion and the result is white smoke until the engine comes up to operating temperature.
Snowtow is offline   Reply With Quote
