I removed the valve covers and the injectors were tight. I did find two glow plugs that needed replacement. I also disconnected the supply and return fuel lines and blew them out. The stange thing is when the tank selector was switched to the rear tank and I put air into the system I got fuel out the supply end. When I did the front tank I got no fuel???? To recap the rear tank is the one that makes the engine run like it is out of fuel at 1/4 tank. Well I cranked the engine and the very light smoke is still there it idle and increases as rpms are . Somehow I'm siding towards water coming from the cooling system. The engine does start right up and actually runs pretty good.
1997PS DW CREWCAB., 3" DOWN PIPE WITH 4" EXHAUST, SUPERCHIP PROGRAMER, K&N FILTER
