powersteering pump ? - Diesel Forum - TheDieselStop.com
Old 06-18-2009, 10:18 PM   #1 (permalink)
Looks like the powersteering pump is going so i'm gonna replace it before it goes out completely. I understand that I need to pull the pully off. Is it pressed back on?
1996 F-350 psd crew drw, demuffed, fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! Stancor gpr (12/26/07) Coolant filter (11-1-2008) Relocated Block heater plug (1/01/2011) Tranni by JOHN WOOD (12-08-2009) Thanks JOHN more mods to come.
fordmedic is offline
Old 06-18-2009, 11:07 PM   #2 (permalink)
DaveBey's Avatar
My Photos: (203)
fordmedic - Yup; the pulley is pressed back on. It's kind of a tight fit for the remover between the pulley shaft and the fan shroud. Or at lease it was on mine. I had to change the power steering pump when I converted to Hydroboost and I think I removed the power steering pump bracket with the pump still attached to make it easier.
Cheers from Claremore, OK!
Dave
1996 F-350 XLT CC SRW 4x4 BTS-E4OD●4L10●Tyrant Diesel chip●Hypermax H2E, intercooler, exhaust●TE-T500●7.3L Regulated Return Fuel System●215 amp generator●International water pump●Hydro-Boost●6.0L Fan●APCM 245,000 happy miles
DZLJIM 3:16
~~NTxPSA - Hold my beer and watch this.~~
DaveBey is offline
Old 06-20-2009, 02:41 PM   #3 (permalink)
Window&Door's Avatar
How do you know when a pump is starting to go? Three months ago I had a hard line with a bad flare pop-off two miles and five turns from home, no doubt I pumped all the fluid out, those trucks are hard to turn with no power btw. Got a new line from O'Reily and some fluid, back on the road in an hour. My fluid is at the mark but I hear howling and growling and feel vibrations in the wheel synchronized with the sounds. Do I need to shop for a pump or wait till it gets worse? I like to repair things on my own time 'cause if its gonna go, its gonna go on a Saturday night.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 06-21-2009, 02:11 AM   #4 (permalink)
If it's howling and growling I would replace it before a sat night. I just did the AZ i think it was 49.99 with a 15.00 core return. If you need any help let me know. Buena Park is local.
