Problem in Steering Column? - Diesel Forum - TheDieselStop.com
Old 07-07-2009, 01:20 PM   #1 (permalink)
Question Problem in Steering Column?
Is there a way to test for problems in the steering column without taking it apart? I have a noise which sounds like a metallic rubbing sounds when I am in a slow hard turn. I know there are bearings in the steering column so that might be the problem but I would like to know for sure without completely tearing it apart. It doesn't sound like an easy job to do.
Thanks,
Griz
02 F250, 4X4, 4R100, 3.73, Amsoil Air Filter, B&M Transmission Pan, Edge CTS Digital Gage, Tymar 4" Exhaust, HPX & TS 6 Position Chip. IH Bellowed Up-Pipes, RiffRaff AIH delete plug and Intercooler boots, 6.0 Transmission Cooler.
Griz is offline
Old 07-07-2009, 02:16 PM   #2 (permalink)
fordsforever73's Avatar
My Photos: (21)
Feedback Score: 2 reviews
Mine did the same...I took it apart and found that the contacts for the horn were dry. I put some dielectric grease on them and it was good after that. I ended up having to do that every year or so.
05 F-350 Crewcab 4x4, 6.0, Auto, Dually, My new Tow Rig
95 F-350 Crewcab 4x4, 7.3, Auto, Awesome Tow Rig...Sold on May 17/09 (went to a good home)
80 F-250 4X4, 429, 4 Speed, Lifted, Solid Axles, Boggers, 450,000km and going strong...Gonna Go
90 Bronco, Work in Progress
fordsforever73 is offline
Old 07-07-2009, 03:32 PM   #3 (permalink)
Really...where are the contacts for the horn?
Griz is offline
Old 07-07-2009, 05:27 PM   #4 (permalink)
My Photos: (21)
You have to pull steering wheel off and then you'll see there is a springy copper tab (contact) that slides on a copper ring. Sometimes the tab may even wear a groove in the ring causing noise. The one I did, didn't have cruise or even tilt steering, so I'm not sure what entails pulling the steering wheel on those models.
Old 07-07-2009, 07:18 PM   #5 (permalink)
Okay...maybe mine is different then. I have cruise control and tilt steering. It appears the contacts for the horn are inside the steering wheel pad assembly. The spring tab idea though sounds about right for the sound I am hearing. I guess there is no other way around it but to pull the steering wheel off and have a look see.
Griz
Griz is offline
Old 07-08-2009, 11:52 AM   #6 (permalink)
Ive got the same sound. At first I thought it was my power steering pump but its brand new. I just put a new steering wheel on and saw the 4 horn contacts and didnt think to grease them. Ill try that and see if it work. My stepdad said it felt like a bearing in the steering column was bad or something.
texascamber is offline
Old 07-08-2009, 12:26 PM   #7 (permalink)
There are two bearings in the steering wheel column assembly. I plan to pull the steering wheel and give the internals the greasy eye inspection and see what's is up. I don't need steering problems down the road.
Griz
Griz is offline
Old 07-09-2009, 12:56 PM   #8 (permalink)
Some of us have a tendency to grab the wheel to assist us with getting in. The steering shaft wears out and the bearings go. Don't wait to fix this. It cost me a new shaft, only available from FORD, plust three days repair time. Luckily I have an extra car but it's still not a fun job to do. The wheel gets all sloppy in the column and could lock up. Hence you won't be able to steer it!
1996 F250 Crew Cab "Mean Green" 24 inch "Bullet" resonator, Superchips Power Programmer, K$N Air filter,crossed-drilled and balanced rotors, super duty pads,Detroit locker with 4.10 gears,24" front cooler, 24" frame rail cooler. Pioneer receiver with 6 disc changer, two 10" JL Audio subs,Kenwood 600 watt mono amp, Pioneer four channel amp pushing Pioneers in the doors.
Txfishermn is offline
