PSD's idling in traffic? - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 11:38 PM   #1 (permalink)
My Photos: (15)
Just curious, how well do PSD's tolerate idling in traffic for long periods of time compared to a gas engine?
Mike
Runboy is offline
Old 03-05-2005, 12:05 AM   #2 (permalink)
Re: PSD's idling in traffic?
Waaaaay better, from a heat point of view. The longer they idle the cooler they get, to the point that you should idle it up a bit when stopped for extended periods. If you have an automatic, you should put it in nuetral if not moving for awhile as the converter generates alot of heat when not locked.
JOAT is offline
Old 03-05-2005, 11:07 AM   #3 (permalink)
AggiePSD's Avatar
JOAT, I remember reading somewhere that it is better to leave the E4OD in park if the truck will be running for some time. I believe the pump will not pump fluid to all critical areas in nuetral, only in park. That is why we check the fluid level in park, not nuetral.
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Truck & Other Pics - More Truck & Other Pics
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
AggiePSD is offline
Old 03-05-2005, 08:34 PM   #4 (permalink)
ahh that dude will Idle all day and all night as long as it has diesel. It IS good to idle it up if its idleing for more than 30 mins due to whats known as "diesel wash". Diesel wash is where the the unburnt fuel washes the cylinder walls. I think 1200 rpms is a good idle up number. Dont let this scare ya tho, if your just in stop and go traffic i really wouldnt worry about it.
Thanks,
Jeff
1956 F-250 Project Stroke
1996 F-250 Powerstoke Diesel XLT,
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TW Chip and some other neat stuff.
1999 F-450 4x4 11ft flatbed, soon to have a 6k crane for my mechanic jobs. Bone stock.
2002 F-150 Supercrew daily commuter
WEBSHOTS-->http://community.webshots.com/user/dieselwiezil
-->http://houstonareapowerstrokes.com
DieselWiezil is offline
Old 03-05-2005, 08:55 PM   #5 (permalink)
i think we also call it "wet stacking", my understanding was that the un-burnt fuelwill build up on the valves as carbon and cause bad seal, and thats bad, so get an AIC for over half an hour straight. If you do have it idle for a while in a unavoidable situation, get it hot asap, go on the highway with a load for a buncha miles and burn all the crap off.
I think thats the theory idea of it, someone correct me if im wrong
Don
-Don
'97 F-250 HD SC LB, 4x4 7.3, Tymar intake, Streamlight rechargeable, strobes, leveled out. Last of the OBS's
'03 F-350 SC LB, 4x4 7.3, loaded, 3.5" DP to 4" Ex, tymar intake, strobes and LEDs galore. windshield mount 3 gaude pod, DP F5(HI,stock,60T,80E,120R),BTS VB, 2.5" leveing kit. Toyo 315s. Last of the 7.3's
Godofdew11 is offline
Old 03-05-2005, 09:00 PM   #6 (permalink)
Stymie's Avatar
Or just a get high idle setting on your chip... everyone has a chip right... [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2008 Ford F-250 CC SB
6" Stage II Pro Comp Lift
17x9 Pro Comp 7189
37x12.5 BFG M/T KM2's
Spartan/4" duals/AFE
Try the SEARCH Button
Stymie is offline
