Engine out !! also orded water pump fuel pump all hoses and new belt....
truck is red!!! what color should I paint the STROKER? RED---BLACK--OR--BLUE any susjestions for the "manifolds and up pipes" [img]/ubbthreads/images/graemlins/smokin.gif[/img] (I have factory GRAY high temp from EASTWOOD)
97 F350 dulie knapheid utility body 7.3 PSD 4x4 8611 LP BLIZZARD plow 8' ss sander diomd plate aulimiumn top boxes ladder rack whalen9004 strobe 6 under cover strobes on board air compressor air ride front and rear spin on trany filter 28 gvw trany cooler w/ fan modified ac condencer as trany cooler down pipe power windows and locks piller gauges piro ,bost ,top shelf incloods air pressure gauge trany temp strobe control, sander control and cb 83000 miles 2004 style headlights clear corners and turns plug in jumpers , grill painted to match truck visor over windshield.5" duel stacks,magnaflow muffler,ss simulators,8 way power leather buckets,2002 dodge console,water filter,5 electric fans,air Horns,215 amp altonator,gruip 31 batteries,tymar intake,5200 lbs rear springs http://community.webshots.com/user/earnies2
BLUE! I did mine when I built the motor and I used carb cleaner to prep the parts. The paint has seen over 20,000mi and pressure washing with no problems. I only painted the heads, valve covers (removed sticker), and oil pan as thats all you can see. One other small detail, I painted the valley white!
Quite a chore gettin that big b@st@rd out of there? [img]/ubbthreads/images/graemlins/grin.gif[/img]
96 F-350 4x4 CC LB, International block and heads from Mcandless IH in Denver, <span style="color: red">Baby Swamps </span>, Luk Cerametallic Clutch, 5" straight exhaust,5 speed ZF, 4.10's, Evolution programmer, Banks brake, non-EBPV IH turbopedestal, AFE Magnum force, CA reg. kit, 12,000 lb. Milemarker on reciever mount, 215amp ambulance alt., 33" muds on factory aluminum, Class 5 bumper hitch, hidden gooseneck, pillar gauges, fosgate amp, 12" sub.
Colorado National Gaurd.
"Firearms stand next in importance to the constitution itself. They are the American people's liberty, teeth and keystone under independece. When Firearms go, all go's. We need them every hour!"
President GEORGE WASHINGTON
Color is total preference of taste.
Black with red accents for me.
Why did you pull the engine?
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
I pulled the engine because of rotted oil pan, brake lines, trany lines, ps lines, exh maninfolds, and in general when i opened the hood i was embarrassed, truck has 65k mi. I looked at a 2005 for replacing this truck, 58k by the time i'm done duplicating this one. Decided instead of buying new, to stick 5k into this truck. It only has 65k mi, runs great, and looks good. I'm just looking for suggestions on any other things i can do. Truck is a work truck. Did you gut your EBPV? What does this accomplish and how do you do it? Are there any benefits or downsides? By the way...Bought 5in stacks for the bed. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Did you change the downpipe? If yes or are going to, yes gut the EBPV. This gets rid of the flapper that closes when the engine is cold. Supposed to aid in warm up. Cut it out and plug the hole from the shaft.
Rick H...
HIS
HERS
Isnt there a post on that? do I have to remove the exhaust back pressure sender. Well here is a update!!! oil pan and dipstick is on,new water pump done, turbo off,fuel filter off, fuel pump off, moter pressure washed I need to get the seals for the rear fuel lines and the blue ruber hoses for the fuel pump,also got new fuel lines from the filter back to the tank. had to cut the exhaust bolts off the up pipes they look like nuts and bolts if not they will be (stainless) I broke one bolt from the turbo to the y block at the top need to drill that out. If you had to bet would you think the exhaust manifold bolts were seezed in the manifolds or in the head,I'm thinking about trying to get them out to change them ? [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Seized in the maniofold. When you go back, use hi temp anti seize where the bolts go through the manifold.
Just un plug the sensor. You can put a dongole on it to feed the PCM the correct signal all the time. Cost about 30 bucks.
WHile gutting the EBPV you could also remove some of the metal, that thing is thick. I think I took off like 20-30k and then honed it out.
Rick H...
HIS
HERS
Not sure but it waseasy to do while it was off. Just took a dremel and cut some metal out, then used a small engine hone on a drill to smooth it out.
Rick H...
HIS
HERS
