Quick, help! Surging while driving - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 06:17 PM   #1 (permalink)
I was just driving home, and after I turned the corner at idle, my truck surged up and down three times than stopped doing it, now it seems fine, RPMs went from idle to 1500 or so just up and down, really strange, PCM or something? Anybody have any ideas??? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
scotts97 is offline
Old 03-04-2005, 11:57 PM   #2 (permalink)
Re: Quick, help! Surging while driving
Anybody, anybody??
97 F250 CCSB,Dana 60 stright axel conversion,3:55`s,Tymar intake,3" down pipe, 4" Diamond exhaust,5" stainless tip, no kitty,Superchip 1705,35x12.5 17BFG/MT sipped,RanchoRS9000X,Energy Suspension Bushings throught,Warn bumper&Winch,canopy,17x9 Eagle alloys,Warn hubs,Mag-Hytec Diff covers with Amsoil,Stainless wheel flares,stainless rockers & bed trim,Tru-cool 4590,Autometer guages and A-piller tri-mount
scotts97 is offline
Old 03-05-2005, 12:40 AM   #3 (permalink)
Are you running a chip? A loose chip could cause that. I'd also check your valve cover harness connectors for a burnt pin. Those things are pretty easy without tearing into much.
Gymbo is offline
Old 03-05-2005, 12:54 AM   #4 (permalink)
I`m not sure why my truck info didnt come across in the first post, my truck has the hypertech programer, just did the glow plugs a couple of months ago, gaskets looked fine, not doing it now, just that one time, but it makes me nervous, I dont want it doing it when I really need the truck and when its not close to home.
scotts97 is offline
Old 03-05-2005, 09:18 AM   #5 (permalink)
My truck did the exact same thing a couple of weeks ago. I had a couple of other symtoms, indicating my alternator was going south. Had the batteries checked they were ok, the alternator was checked also, showed it was charging fine at the time, but an error came out on the tester that the diodes were going out. They gave me a "new" rebuilt one, put it on and it has been fine ever since. I had it checked at Auto Zone. Good luck
Scott
1996 5 speed, extended cab, 4x4, stock, 159000 miles
nascarjunky is offline
Old 03-05-2005, 10:41 AM   #6 (permalink)
it check your battery connections real good. if ya got a battery thats going south on you and internally shorting out that will do it.
is the tach acting normal?
what does the voltmeter do when it does this?
97 F250HD 4X4 210K MI
4 LINKED FRONT AND REAR ON AIR
00 F350 4X4 CC
RIP CHRIS. 03/09/05
http://community.webshots.com/user/barebackjake
barebackjake is offline
Old 03-05-2005, 12:27 PM   #7 (permalink)
When it happened to me my voltmeter didn't move at all but my tach sure did.
Old 03-05-2005, 03:22 PM   #8 (permalink)
I just put two brand new batteries, new GPR as well, could it be the CPS? it didnt do it today on the way to work at all, I will have to see if it shot any codes when I get home from work, I`ll double check the voltage and the Tach jumped up and down when it happened, it only lasted about 5 seconds, but my wife was 500 yards away and she heard it. Strange Huh
scotts97 is offline
