Ran rough, heavy blue-white smoke, stalled ?? - Diesel Forum - TheDieselStop.com
Old 01-29-2007, 05:00 PM   #1 (permalink)
My Photos: (60)
Coming home from work today I was running on the rear tank (had been for 75 miles or so) and the truck started to miss, like it dropped a cylinder then another then another. Temp was 12* this morning when I started. Truck started normally, I left work and made it about 2 miles when this started. No CEL, the truck started smoking very heavy like an old Mack when started very cold (no mosquitos around, that's for sure!) Truck finally stalled, I switched to the front tank and tried to restart. It started but was running rough, smoothed out and ran OK. Once on the interstate I switched back to the rear tank and everything is fine. I got home and parked this morning and went to bed. This afternoon truck started OK (one cylinder dead, maybe two). The cold miss went away after 30 seconds or so - I think it's time for glow plugs again.
I was thinking maybe some ice in the system somewhere, any ideas?
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 01-29-2007, 05:04 PM   #2 (permalink)
Re: Ran rough, heavy blue-white smoke, stalled ??
Sounds electrical. Or does it feel like your running out of fuel? I'd say first thing is check all the plugs on the V/C's to make sure they are in tight and not melted. Glowplugs wouldnt matter b/c you were going down the road when this had all started to happen. Could it be fuel gelling?
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 01-29-2007, 05:12 PM   #3 (permalink)
Sounds like an issue between the rear tank & the fuel tank switch, I got better after that...just a thought...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 01-29-2007, 05:18 PM   #4 (permalink)
My Photos: (60)
Tim, I was thinking fuel gelling as well. I have never run across wiring problems with injectors/glow plugs that did not set a CEL. I did put some fuel treatment in the rear tank (front tank is about empty)
action4478 - you may have it. It did not occur to me that the fuel tank selector solenoid may have just hung up on something or maybe a bit of ice in it from the sudden drop in temperature.
Thanks for the input.
Dave / Believer45
Old 01-29-2007, 05:55 PM   #5 (permalink)
I was dealing with one truck a while back that kept on shutting off injectors and it never set a CEL. It was a 97. Turned out to be IDM and engine wiring harness. The truck had eaten 3 IDM's before we decided to change the engine wiring harness.
Truck pics
