Well lets start like this. This is my second rear end I have killed. The first the pinion bearings failed and made a mess and the one that replaced it was a factory 3.55 or watever it is with limited slip that had 80K on it. Now it Do drag race and run in pulls occasionally but just out of the blue the rear end started sounding like it had marbles in it at slow speeds and whines while driving. There was no metal shavings or any chipped teeth or abnormal wear. Is it possible for the pinion depth to change over time if I didn't touch the yoke or crush collar?? Could the back lash have come out of whack from abuse?? Im at a loss and don't want to start slinging parts I don't need.
Diesel Tech For Yardmaster INC.. College Degree In Heavy Duty Diesel and Power Generator Systems
1997 F-250 Heavy Duty 4x4 Off Road EX.Cab Short Bed. -4" Suspension Lift - 4" exhaust - 3" Downpipe - 5" Stacks - 10Kmod - Shimmed FPR - Home made air intake - Rosewood Stage 1's - TS 6pos Chip - 4:10 gears - Valair SMF conversion - currently tore apart for restoration
2004 F-350 FX4 - 4" Turbo Back - WORST truck I have ever owned - For sale
Ok, you drag race...Run in pulls.
Could it be that you (hurt it) didn't quite break but started something on it's way. Now it's starting to manifest it's self. Anything can be broken. Just a matter of time. Hey you abused it. Now it's like an old dog that don't like the way you treat it. GRRRRR!!!
You'll just have to take it apart and try and fined or feel the roughness.
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
I believe any changes, or re anything, should require you to measure and make sure of gear alignment and lash. Do it up right and it will last longer. Other wise it will just be a matter of time. Or you could get lucky. Do you feel lucky today.
Jim
