Rear Differential - Diesel Forum - TheDieselStop.com
Old 09-09-2011, 03:45 PM   #1 (permalink)
Rear Differential
I have a 1997 ford f350 i do not have a metal tag on my rear end and im trying to find out if i have a locker of not in it to determine what oil i need to run and how much oil. Ford says 75-140 synthetic...others say 80-90 gear oil but i dunno if i need the additive anyone have any ideas i think i have 355's in it.
2006 Ford F350 6.0 Liter
MBRP 4" exhaust
SuperChip tuner
AFE stage 2 intake
Retro-Solutions 6000K HID Headlights, and Fogs
smithw44 is offline   Reply With Quote
Old 09-09-2011, 05:04 PM   #2 (permalink)
blageurt's Avatar
My Photos: (9)
As soon as you remove the cover you will see what it is ... the VIN and the door sticker will tell you the Axle code ... 39 is the Open 3:55 ....I use 80W90 and change it every 50,000 kms ( half of recommended service interval) Alot of guys use synthetic but since I change it myself and am Old School I use Dino....
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Michelin LTX
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
blageurt is offline   Reply With Quote
Old 09-09-2011, 05:28 PM   #3 (permalink)
jack the rear axle off of the ground..truck in neutral...turn either wheel..if the other turns the same way..posi..if not open..open,,75w140,,,posi whatever Ford says for that year..
94_turbo is offline   Reply With Quote
Old 09-09-2011, 05:58 PM   #4 (permalink)
What does it say under "Axle" on the door jamb label?
madpogue is offline   Reply With Quote
Old 09-11-2011, 07:10 AM   #5 (permalink)
Never thought about about looking on the door jamb I will do that today and post on here. Thanks for everyones replies
MBRP 4" exhaust
SuperChip tuner
AFE stage 2 intake
Old 09-11-2011, 04:04 PM   #6 (permalink)
the axle code on the door say C9
MBRP 4" exhaust
SuperChip tuner
AFE stage 2 intake
Old 09-11-2011, 04:06 PM   #7 (permalink)
axle code on the door says C9 i called ford with the vin number and they said there computer doesnt go back usually more then 10 years couldnt help me told me to find metal tag on axle...to look it up what numbers in the vin would tell me what kind axle is in this?
MBRP 4" exhaust
SuperChip tuner
AFE stage 2 intake
Old 09-11-2011, 05:29 PM   #8 (permalink)
dieselsmokerdoug's Avatar
My Photos: (21)
with the info i have c9 is a limited slip with 355 gears
1997 F250 HD XLT 4x4 ext cab long box mbrp 4"pipes with 6"tip& 3"downpipe, 410 rear gears, add a leaf on front , rebuilt trans e4od 12"x13"transcooler with a thermostatic fan , TOYO open country AT's 285x78x16 & opened up air box with a k&n filter. 2012 Salem Grand Villa 408reds with 3 slides
dieselsmokerdoug is offline   Reply With Quote
Old 09-11-2011, 05:53 PM   #9 (permalink)
yeh thank you!i looked it up on google and found a chart from ford listing all there rear ends and the axle code. appreciate your help!
MBRP 4" exhaust
SuperChip tuner
AFE stage 2 intake
