rear differential question - Diesel Forum - TheDieselStop.com
Old 09-05-2006, 10:39 PM   #1 (permalink)
My Photos: (33)
one of my rear u joint bolts broke mysteriously and left half of it in the yoke. i want to take the pinion nut off to get the yoke off so i can put it in a vice and try to get the remains of the bolt out. my question is can i just put the yoke back on without worry or do i have to check the gear adjustment and stuff?
brandan
1996 F-250 CC SB 4X4, 7" lift, D-60 conversion, superduty springs front and rear, 37x13.50x17 xtreme all terrains, tymar intake, mbrp 4" exhaust, 6 pos wildman chip.
Truck Pics
"To get the things you have never had before, you have to do things you have never done before." ~Henry Ford~
brandan is offline
Old 09-05-2006, 10:44 PM   #2 (permalink)
buford856's Avatar
Re: rear differential question
As long as you dont take anything out but the yoke you will be fine. Just be careful not to damage the oil seal when you reinstall the yoke.
-Ben
2003 F250SD, 7.3L, CC, SB, FX4,4x4, Lariat
Got a few tricks under the hood, nothin worth braggin about.
buford856 is offline
Old 09-05-2006, 10:49 PM   #3 (permalink)
Briansshop's Avatar
You can prob get away w/it,but to do it the right way you would need to pull the carrier out to set the pinion preload.Just a little more work and you know it's right.
Brian
95 F350 CC XLT,bought new as 2x Dually,owner converted to 4x4,up on 38s, Baumann TCS controlled E4OD.
http://s77.photobucket.com/albums/j70/Briansshop/
Just getting broken in, 50,000 miles!
Briansshop is offline
Old 09-05-2006, 11:10 PM   #4 (permalink)
Tom S's Avatar
My Photos: (20)
Can you pull and replace the carrier without screwing with any of the setup. I just want to know in case this every happens to me.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood, 14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
Old 09-05-2006, 11:48 PM   #5 (permalink)
yes, as long as you dont loosen the ring gear and put all the shims and bolts back EXACTLY as they came out you are fine. i have had to pull my carrier out and replace it on the trail while sitting next to a stream on a rock in my 72 bronco. i carry a spare for that! lol
-cutts-
My Picasa Web Album
96 F350 PSD 4x4 CC/LB 5spd XLT Ranch Hands F/R, 6637 mod, 4.5" straight pipe, tymar 3-4" DP, Dominator 66 turbo, Banks IC system, DIY Stage-I's, TW 4-pos chip, 37" SuperSwampers, autometer gauges,RAM laptop mount w/AI OBD diagnostics, fold down g/n hitch, OBA system with York and dual trumpet air horns, bronco 33gal fuel tank
72 bronco 302/435/twinsticked D20/D60/10.25 welded F/R, hydro assist, 39.5" stretched WB to 105", 1410 yokes/shafts, Staz custom double beadlocks, CroMo shafts front shafts with 35 spline outers and sexy lady drive slugs, GLO diamond tread diff covers, custom cage, mesh floor, custom diamond aluminum dash overlay, wristed radius arm, homemade shackle ladder bar
Fishmanndotcom is offline
Old 09-06-2006, 12:12 AM   #6 (permalink)
Definetly do it right. If you loosen the pinion nut, you should remove the carrier and set the preload on the pinion; there really isn't any shortcuts for doing that the right way. IMO I would try to repair the yoke on the truck, even though its a real PITA it would probably be easier in the long run. Get yourself a good set of extractors and go to town. Good luck.
-Peter
96 F250 4X2 CrewCab PSD 4" Fabtech, Authentic Tymar Intake, Dales 4 postiion chip, 3-4" DP, Side exit open exhaust. http://community.webshots.com/user/pjabdel
SOLD--99 F250 4X4 CrewCab PSD 6" Full Traction Suspension, Banks Power Pack, Pyro, ISSPRO TTM, Boost gauge, Rancho 9000s, Custom rear bumper w/ lights,Warn 15,000-that's right 15,000, BFG MT/KO's 37 X 12.5R17's, full custom dash panel
PowerFiend is offline
Old 09-06-2006, 10:04 PM   #7 (permalink)
My Photos: (33)
ok i tried to drill and extract but didnt work and ended up screwing up the threads. i put a new yoke on and tightened it down to what i think the same spot was before. does anyone have a link or instructions on how to adjust the preload?
thanks
brandan
Truck Pics
brandan is offline
Old 09-06-2006, 11:18 PM   #8 (permalink)
Briansshop's Avatar
Brandan, you need a new crush collar and seal for the pinion.The carrier needs to be out of the housing.You hold the yoke and tighten the pinion nut until you reach a set amount of "drag" or pre-load on the pinion bearings.You check it by turning the pinion w/a dial or analog reading in.lbs. torque wrench.There's a pic in my album on the second page of the holding tool I made for the yoke,and you can see the pipe on the 3/4 ratchet-it takes ALOT of torque to crush that collar!Take a look at www.ringpinion.com,I think they have some instructions on there, or I can give you somemore detail if you think you're going to try it.
Brian
