red/white wire identification - Diesel Forum - TheDieselStop.com
Old 12-25-2012, 12:35 PM   #1 (permalink)
I recently had to disconnect the fuel bowl heater wire because it was blowing the 22 fuse. If i remember right it was a red/brown wire. While i was unhooking it i noticed another wire that had been unhooked and taped up. It was red/white and exactly the same gauge as the fuel bowl heater wire. I could not figure out what it went to or why it had been unplugged. Any ideas?
thanks!
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hub: 314,000 miles
dirtyb15 is offline   Reply With Quote
Old 12-25-2012, 03:27 PM   #2 (permalink)
Stan96's Avatar
here's a picture of it, i forget what that thing is called tho, whatever it's called, people usually unplug the wire and use a pipe plug to fill the hole, just don't tighten too much, the housing breaks easily
red/white wire identification-fuelbowl.jpg
1996 F-350 XLT 4x4, e4od, stock, Elect-rustproofing
2004, @32k mi. glowplugs, tires, drag-link
2010, @76k mi. Ball joints, u-joints, rotors
2011, @86k mi. glowplugs, drag-link, trany fluid
2012, @94k mi. Bilsteins, stainless brakelines, fuelbowl, lift pump, waterpump, steering lines, coolant filter
2012, @98k mi. Starter, positive cable, batteries
Stan96 is offline   Reply With Quote
Old 12-28-2012, 01:15 PM   #3 (permalink)
Paul H's Avatar
My Photos: (10)
It is the vacuum sensor, to show you when you have a restricted fuel filter
Paul H
OWNER
2004 Ford F350 6.0L Dualie 246.000 miles with Edge Insight, Early Build 8/03 with 03 engine 20 mpg running empty EGR delete running ELC all stock
1996 Ford F350 7.3L Dualie 340,000 Tony Wildman custom burn,5 inch stacks, good ole girl(in Avatar)
1995 Ford F250 7.3L Regular Cab 255,000 miles Sled Puller
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
Paul H is offline   Reply With Quote
Old 12-28-2012, 01:45 PM   #4 (permalink)
Thanks for the info guys. Wonder why it was unplugged in the first place...
