Reduce cab noise - Diesel Forum - TheDieselStop.com
Old 10-16-2008, 08:22 PM   #1 (permalink)
Reduce cab noise
I have a 97 F-250 7.3 power stroke short bed crew cab. The truck is a 10 with all respects except the engine noise in the cab.
Does anyone know of an enexpensive way to reduce the noise from the engine compartment to the cab ??
97f2507.3 is offline
Old 10-16-2008, 09:08 PM   #2 (permalink)
look up eDead on ebay from Elemental Designs. it's a cost effective alternative to dynamat. they have two different kinds, a mat that you peel apart and adhere to the floor and firewall, or a brush on rubberized kind. i just did the brush on in my 450 and the stuff on the roll in my 150. between the two, i think the stuff on the roll is better.
1999 F-450 crew cab DRW, 6spd. 4" straight exhaust, AFE high flow filter, zoodad, ISSPRO guage set, EBPV delete, CCV mod, DPTuner 80 econo, Wicked Wheel, Midwest Transmission Short Shift Kit
2004 F-150 reg. cab - bagged, shaved, and completely rid of all chrome. street queen.
Hawker is offline
Old 10-17-2008, 07:24 AM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Biggest improvement I did was to stick pink insulation around the shifter boots from under the truck.
Makes a huge difference and will eventually fall out making you sick of your truck again. Just stuff some more up there and your good to go again.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
