Replaced the water pump but I'm still leaking - Diesel Forum - TheDieselStop.com
Old 01-14-2009, 09:23 PM   #1 (permalink)
Exclamation Replaced the water pump but I'm still leaking
So I just replaced the water pump and I'm still leaking under the pump and around the crank. I have absolutely NO IDEA where this is coming from. I'm sorry to be such a pain and creating so many threads but I'm completely at a loss here.
It's a pretty steady drip once the engine gets running. It takes about 10 seconds before it starts dripping once the engine is running. It really looks like it's coming from under the water pump and on top of the crank pulley.
PLEASE PLEASE PLEASE!!! I need some answers!!! Anything!!!!
1995 F-250 XLT 4X4 reg cab, long bed, 240,000+ miles, 10k, Western 9 1/2' plow, K&N.
KinkadeIN is offline
Old 01-14-2009, 10:17 PM   #2 (permalink)
johndeerebones's Avatar
Go to napa and get a new thermostat housing and gasket, replace it and put some rtv on the new oring. I don't normally put rtv on anything, but the thermostat housings are a very persistent leak source, they are pot metal. I just replaced my pump, it was bad, was leaking profusely outta the weep hole, fixed that, but i have a trickle at times at the thermostat housing now, so I have to do the above mentioned when it warms up a bit. My leak is so small it evaporates before it hits the ground, but I can smell it, so it drives me nuts.
Sold, back when the snow was on...
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
My Pics
Truck Pics -Updated-
johndeerebones is offline
Old 01-14-2009, 10:39 PM   #3 (permalink)
I did replace the t-stat housing as well. It did come with a gasket (the old one didn't have one) and I RTV'd the daylights out of it. It is still leaking just a tad from there and I'll deal with that later. However, that's not the source of this leak. This leak is much worse that what's leaking from the t-stat housing.
Old 01-14-2009, 11:42 PM   #4 (permalink)
PSDfreak's Avatar
I have a small leak as well...seems to only pop up when im up in the mountains and its cold out. Its not the water pump as far as I can tell (I replaced the pump about a year ago). It appears to be coming from the front driver side corner of the motor, but up top somewhere...Its a VERY VERY small leak...i've never had to top it off, just bugs me. For the life of me I can not tell where it is coming from...not that its a huge help but thought maybe it sounded similar to your issue.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
Old 01-14-2009, 11:48 PM   #5 (permalink)
169stang's Avatar
My Photos: (5)
The first cold snap of zero degrees....my turd leaked a little from the lower rad hose...on the rad side. I thought my rad was cracked, but it wasn't. I stopped the next day when it warmed up a tad. I looked for cracks, etc. but couldn't find anything.
1997 F350 7.3L CC DRW 2wd
Tymar 3" DP, 4" exhaust, intake. Gutted EBPV, modified pedestal. True-Cool Max tranny cooler. Tony "Wildman" 4 position chip. Autometer gauges
2005 Mustang GT street/drag car. 76MM turbo 800rwhp
1996 Mustang Cobra Mystic #93
1969 Mustang Coupe-302
http://good-times.webshots.com/album...ost=good-times
169stang is offline
Old 01-15-2009, 07:07 AM   #6 (permalink)
Yea, mine is leaking a bit more severe. It speeds up with rpm's and I'd say I'd loose about a gallon of coolant in about an hour or two.
Old 01-15-2009, 11:24 AM   #7 (permalink)
My money is on a pinched waterpump gasket. Dont ask me hw i know. $7.00 at kragen
1996 F-350 psd crew drw, demuffed, fumotoed, home-made intake, edge evo, post triple pillar auto meter gauges,line-x (10-16-05).Seat mod (11-13-05).on-board air(viair 450c) with horns (Kleinn triple train) (8-21-06).Bilsteins (11-28-06)Upgraded headlight harness.IDM MOD by Matty, SOCAPS member <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />thanks Matt!! Stancor gpr (12/26/07) Coolant filter (11-1-2008) Relocated Block heater plug (1/01/2011) Tranni by JOHN WOOD (12-08-2009) Thanks JOHN more mods to come.
fordmedic is offline
Old 01-19-2009, 10:53 PM   #8 (permalink)
97smoker4x4's Avatar
I agree with the last guy, especially if it wasnt leaking from that spot with the old pump. My front engine cover is leaking where it meets the block near the top by the drivers side, and I am getting a small amount of coolant in the oil because of this. I am going to yank the motor this weekend.
97smoker4x4
97 f-250 4x4 superchips programmer, dnpipe, 3gauge pod, pi converter, sonnax sure cure, stancor, ebpv delete, open exhaust, tymar
95 Z 28 Convertible
2003 WR 450
97smoker4x4 is offline
Old 01-20-2009, 12:44 AM   #9 (permalink)
kwcat's Avatar
Send a message via MSN to kwcat Send a message via Yahoo to kwcat
If it gets worse when engine rpms go up I would look at the pump and or the gasket!!! Sounds like that is were leak should be. Let us know if you run into anymore problems.
Paul.
kwcat is offline
Old 01-22-2009, 03:21 PM   #10 (permalink)
OK, so I found the culprit... It was a poorly welded BRAND NEW water neck!!! I took it back to Auto Zone and they replaced the neck and gave me 2 gallons of coolant for my troubles!!! I'm not a big fan of Auto Zone but they did make good on the problem.
Old 01-23-2009, 10:48 AM   #11 (permalink)
Hopefully the coolant they gave you is a low silicate formula. I'm always skeptical of AutoZone.
Snowtow is offline
Old 01-26-2009, 05:12 PM   #12 (permalink)
It was Prestone if that helps.
Old 01-26-2009, 05:50 PM   #13 (permalink)
Not really. If it's low silicate, it will state something like "Low Silicate Formula" or something along those lines right on the front of the bottle. You don't want to use antifreeze in a PSD that isn't low silicate.
Snowtow is offline
