REPLACEMENT BATTERY CABLE ENDS - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 10-25-2006, 04:59 PM Thread Starter
DOES ANYONE KNOW WHERE I CAN PURCHASE NEW BATTERY CABLE ENDS FOR THE POSITIVE CABLES? I AM GOING TO MAKE NEW DUAL BATTERY CABLES, NEED THE PASSENGER SIDE POSITIVE FOR SURE, IT SERVES AS THE POWER TO STARTER, AND GOES TO THE DRIVERS SIDE POSITIVE POST AS WELL. DOES ANYONE MAKE REPLACEMAENT POSITIVE CABLES ALREADY MADE THAT YOU CAN BUY BESIDES FORD?
jmtadey is offline
post #2 of 10 (permalink) Old 10-25-2006, 06:23 PM
PSDfreak's Avatar
Re: REPLACEMENT BATTERY CABLE ENDS
Yes you can get it at powerstrokeshop.com for a lot cheaper than the local ford dealers.
I looked this up about a month ago..I'll post a link here in just a minute.
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 10 (permalink) Old 10-25-2006, 06:27 PM
PSDfreak's Avatar
Here ya go: Positive Battery Cable
It lists it for $60.81 which is cheaper than the dealer by around $40 here at least.
-Casey
PSDfreak is offline
post #4 of 10 (permalink) Old 10-27-2006, 04:53 AM
Thanks for the post casey. Looks like a good site for parts. Mine is getting on in years and miles (going to get an AARP card for it next month.) I replaced the Positive and both negative cables in early October and the Ford part cost me over 135 bucks. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Dave
95 F350 CC/dually. Stock as the new one. Reworked Tranny by BTS. 487,890 miles on it as of Jan 01. 2005. Still runs great. Just turned 510,000 miles on Oct 25, 06. Looking for a better air cleaner. Note, 520,000 today. Oct 13,07
DLDEE is offline
post #5 of 10 (permalink) Old 10-27-2006, 12:11 PM
PSDfreak's Avatar
Yeah they will sure nail ya at the parts counter...Powerstrokeshop was the cheapest/easiest I found.
-Casey
PSDfreak is offline
post #6 of 10 (permalink) Old 10-27-2006, 02:49 PM
this is the one I just installed:
http://cgi.ebay.com/ebaymotors/FORD-DIES...VQQcmdZViewItem
It is great. 1 gauge cable and it is a good fit as well.
<span style="color: #000099"> 96 F-250 CREWCAB POWERSTROKE... Stage 1 injectors... 6 position Tony Wildman chip: stock, economy, daily, tow, hot tow, & Luke Cline Extreme... Superduty IDM mod... Tymar intake... Tymar 3"X4" down pipe... Tymar 4" exhaust... Tymar high pressure oil crossover... 6.0 intercooler-PIPES thanks to GTS... CCV mod... V10 transmission cooler... 203* thermostat... shimmed FPR... gutted EBPV... Monster Box trans... 4.10s... Dana 60 front... LS rear w/ extra qt and a half diff cover... three gauge pod full of Autometer's... AIC... Turbo pedestal mod by Rick96F250 and a 3/8inch shorter bolt on the rear passenger side of the pedestal... Nippondenso starter... THINGS TO DO: get a big turbo, big oil, and big fuel... RSK with SD springs.</span>
<span style="color: #CC0000"> #26</span>
krowell is offline
post #7 of 10 (permalink) Old 10-28-2006, 12:22 AM
Just curious, what about a welding shop? I have heard guys having them made at a welding shop. Anyone do this and what did you pay ?
fordmedic is offline
post #8 of 10 (permalink) Old 10-28-2006, 03:34 AM
PSDfreak's Avatar
I have hear welding shop recommendations as well...Haven't checked it out but I'm sure they would be able to work ya something up.
-Casey
PSDfreak is offline
post #9 of 10 (permalink) Old 10-28-2006, 07:26 AM
Just curious, what about a welding sho? I have heard guys having them made at a welding shop. Anyone do this and what did you pay ?
That is what my cable is from. The upgraded wire is usually 2 gauge. This one is 1 Gauge welding wire. Its very good quality wire. This wire is capable of flowing a lot of amps and has a very tough skin so welders can drag it around. It was a perfect match for my 160 amp Alternator. If I ever go to a 215 amp ALT this wire will still work.
krowell is offline
post #10 of 10 (permalink) Old 10-29-2006, 01:28 PM
rmyers2051's Avatar
I too bought one from Ebay, a bit cheaper than the other one posted Ford Battery Cable
But for what its worth I aint using it on my truck, i'm doing a dual battery setup in my Bronco.Winching eats battery power quickly.
F250Ext. 4x4 5spd. GV overdrive,4.10s,23+mpg
Some people are like slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs!
rmyers2051 is offline
