retrieving engine codes without programmer?? - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 08-18-2005, 07:48 PM Thread Starter
is there any tricks to get the codes out without a programmer? My truck died today and wont run right,has no power whatsoever and idles bad. Need it for work tomarrow
Destruction Overdrive
95 F350 XL SRW 4:10's
BDP S1, D66, 17*, Built Trans, Thumbwheel, Locker, Stacks, Banks Cooler, Stancor GPR
Air21 is offline
post #2 of 5 (permalink) Old 08-18-2005, 11:35 PM
tallfarmboy's Avatar
My Photos: (11)
Re: retrieving engine codes without programmer??
You can get Code Readers from most auto parts stores (AutoZone, O'reilly's, etc..)They will generally loan them to you with a deposit.
If it is missing badly, then more than likely you have a bad injector harness. You might pull each plug for the injectors and look for burnt/melted pins. You can also pull the Valve Covers and check the wires in there too..
Good luck,
TF
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust
tallfarmboy is offline
post #3 of 5 (permalink) Old 08-18-2005, 11:48 PM
depends on year! 94-96' code reader won't work. Some 97's it may work on. You need to find someone with a scanner.
Clayton,
<font color="red">*ASK ME ABOUT MY AWSOME TWILDMAN CHIP*</font>
95'F-350 4x4
SOLD!! (due to exwife!)
99' F-250 CC 4x4, 4r100 SOLD (due to exwife!)
99' F-350 SC,2WD,auto (New GF's truck!!!!)
Ride It, Rope It, POWERSTROKE IT!
bulrid8 is offline
post #4 of 5 (permalink) Old 08-19-2005, 05:31 AM
My 96 works with my alex pepper software just fine. It will also connect to a cheep scan tool, although they can't do to much for our ford enhanced trucks. You need to find a ford enhanced scan tool.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by
, Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
TimMiller is offline
post #5 of 5 (permalink) Old 08-19-2005, 06:30 PM
Yes, Your software is a scanner. But, the code readers don't have the Ford enhanced trouble codes.
Clayton,
95'F-350 4x4
bulrid8 is offline
