Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 05-11-2008, 08:19 PM   #1 (permalink)
rough running after sitting for 2 weeks
Truck sat for sale for 2 weeks and I went to crank it up and it seems to be running on 4 cyls , I will bring the scanner home on monday, but until then any ideas????? Ran great up until it was parked. It did rain about 2 inches last night and the truck has not been parked in the rain up until I put it up for sale . IDM ????? It dose have codes , the light is on, will checkthem. THA Chris
97 SRW CC F350, 4x4, 3 4 down pipe, 4 in exhaust AERO TURBINE 4040, DIY tymar intake, superchip 1705,16x10 eagle alloys,315 BFGs, superduty add a leaves, AC mod,CCV mod, intercooler is next.
gaducker is offline
Old 05-12-2008, 05:07 PM   #2 (permalink)
No one???? I checked the codes and I have a camshaft position sensor inconsitient. Will the cps make it run that bad, It will not even pull itsself in drive... I had one awhile back and the cps just made it idel very rough, It would still go but this truck wont move. Has anyone exprienced a cps just going out like that. Ran fine when I parked it and when I went to start it the next time it never even acted like it was fireing right. THA Chris
gaducker is offline
Old 05-12-2008, 07:25 PM   #3 (permalink)
ammayernick's Avatar
Same thing happened to my truck when it was at the body shop. Ran a little rough but not as bad as you describe. I also get the CPS inconsistant code. Must have been a fuel problem cuz it cleared up after a day or two. I've read that diesel fuel breeds algae when it sits too long. Try draining the fuel bowl and taking it for a good run. I have to admit I've been eyeing your truck since you posted it. Looks like my rigs twin.
1997 F350 7.3 PSD Black Crew Cab XLT 4X45 Speed Manual * 202,000 miles original owner* Banks Power Pack * DP Tuner F5 Chip * Centerforce Dual Friction w/SMF * Baby Swamps Phantom II Pyrometer Fuel and Boost Gauges * Customized Dual 4" Diamond Eye SS Exhaust w/offroad pipe * Dieselsite Turbo Saver * Amsoil Bypass Filter * AFE * Viair Onboard * Mag-Hytec Diff Cover * Amsoil Everywhere * LT315/70R17/D on M/T Classic Locks * PULSE HPOP and CPR Fuel System*
http://community.webshots.com/user/ammayernick
ammayernick is offline
Old 05-13-2008, 01:24 PM   #4 (permalink)
The code that is coming up now is po 1111 pass 49 state????? What the dose that mean, It still runs like only half the cyl are firing, But when I pull the uvch at the valve cover it kills it. all four plugs kill it so I would assume all are trying to work. I tried to disconnect batt for a while but that did not help any. I will get a cps and try that. Any thoughts Tha Chris
gaducker is offline
Old 05-13-2008, 02:36 PM   #5 (permalink)
STurbo90's Avatar
My Photos: (9)
1111 means no system faults detected I believe.
Usually unplugging one harness will not kill it, if all are killing it individually, I think it is a cumulative problem.
did you check the fuel bowl, maybe you have a lot of water in the tanks and sitting for 2 weeks let it settle.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 05-13-2008, 02:55 PM   #6 (permalink)
I thought about that, I even thought about someone vandilizeing it and puting something in the tank, But IT never ran right as soon as it fire off it was running like crap, If it was water os sugar or anything I would have thought it would have ran ok for a few minutes before it started runing rough. I have a new CPS so I will try it today. If thats not it will the CPS work on my 03???? THA Chris
gaducker is offline
Old 05-13-2008, 08:10 PM   #7 (permalink)
Well I pulled the truck up my drive way to flat ground and forced it to go down the road, after about 1/2 mile it started to clear up and it finally came back to life. I guess its trying to tell me to drive her and not sale it. I did not change the cps so I have no idea. Air in the fuel system??? I have no leaks After it cleared up it passesd a cyl cont test. Thanks Chris
gaducker is offline
Old 05-16-2008, 11:31 AM   #8 (permalink)
Gaducker,
An uneducated guess would be that you may have a high pressure oil pump draining down while sitting for long periods of time. When you start it, air is introduced to the system, and takes a while to work its way out of the system. Just replaced the IPR on my '97, and it ran horrible. I increased the idle speed to about 1500 rpm's for several minutes and when I allowed the engine ot return to normal idle, it sounded much better.
After driving approximately 10 miles, it runs just like it did before, which is very smooth for a diesel.
Weazer
1997 F250 4X4 133K LONG BED/STANDARD CAB 5 SPEED. TYMAR INTAKE/DIAMOND EYE 4" EXHAUST
Weazer97 is offline
Old 05-19-2008, 08:32 AM   #9 (permalink)
Well I drove it to work toady and it ran fine for a few minutes and it started doing the same thing after I pulled out of the drive way. It cleared up after about 60 sec and then did it again a few miles down the road but only for about 30 sec. When I push the pedal to the floor and let off it cleard up. I have not put the new cps on yet but thought I would try that today. ant thoughts. I have 700 psi at idel and 2700 when going down the road hp oil that is, But I have not had the scanner hooked up while it was actually acting up. I may have the truck sold today and would like to figure this out before the guy takes the truck any help would be greatly appreicated. THA Chris
gaducker is offline
