Runs but won't start without help - Diesel Forum - TheDieselStop.com
Old 04-16-2009, 01:35 PM   #1 (permalink)
stang65fst's Avatar
Unhappy Runs but won't start without help
Well I still have a starting issue. IPR has been replaced and the truck still won't start cold or hot without starting fluid.
I was told it might be the ICP? As of right now I have no engine light and have no code showing on the truck.
I have great fuel pressure so not an issue there.
Need some help from TDS on this one. I am stumped.
Todd
AKA Toad
stang65fst is offline
Old 04-16-2009, 02:48 PM   #2 (permalink)
Excavator's Avatar
My Photos: (11)
fast check on ICP is just unplug it and if starts then replace the ICP. It will set a check engine light when you unplug it because it sets the ICP pressure at default of 725 psi.
Jim Sult / Excavator (we dig it)
Trying to fix it? KISS IT "KEEP IT SIMPLE STUPID"
Avatar- purchased off Ford lot as NON RUNNING ENGINE - I drove it off lot in 1 hour/ my everyday 1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60 , Bilsteins shocks, Greggs MB AutoTrans, Baby Swamps,Tony Wildman Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
1997 F350 XL 2x4 DRW Powerstroke , DP Tuner PCM, 5 speed,Luk Clutch Tymar intake. DPP downpipe, 185,000 miles
Truck Pics
HOME of FIRST Banjo Bolt Ratchet
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Excavator is offline
Old 04-16-2009, 05:13 PM   #3 (permalink)
MarkEkberg's Avatar
My Photos: (13)
As stated in your other post. Looking like injector o-rings.
Open the valve covers and crank. You will find a injector that is dumping oil out the return tube.
If your doing one may as well do them all.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 04-16-2009, 07:45 PM   #4 (permalink)
stang65fst's Avatar
Well I replaced the ICP. I'm sure I just dumped money down a rabbit hole, and still no start. Injector orings, that just seems crazy as I just replaced them less then 50k ago, the entire injector. I guess it could be but just seems so hard to believe. Also did the under valve cover wiring, glow plugs, and valve cover gaskets.
Anyone else have any ideas?
Todd
AKA Toad
Old 04-16-2009, 09:13 PM   #5 (permalink)
Excavator's Avatar
My Photos: (11)
Might just have weak starter or batts and not spinning fast enough
If injector o rings are bad it would show up with scanner or HPOP gauge. The ICP would be lower than the required 500 psi when cranking but a weak starter could also crank it over too slow to achive the rpm needed to activate the injectors
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 04-17-2009, 07:33 AM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
It will show up on a hard plumbed guage, but electrically everything checks out. At least that is what mine did.
Old 04-17-2009, 07:54 AM   #7 (permalink)
stang65fst's Avatar
A scanner, as in what Ford uses will tell if o rings are bad? The HPOP gauge where would it tap in on top of the reservoir there?
Would/could it be cause by a weak or bad HPOP?
Starter is DB electrical, 4 months old. Batteries are less than a year old and in good working order had them tested.
Todd
AKA Toad
Old 04-17-2009, 11:12 AM   #8 (permalink)
sounds like orings I had the tranny savers the top orings were not the updated ones they were leaking oil bad pull the valve covers like they have said you will see oil puking at the bottom of the injector
Ford F250 Short Bed Extended Cab/190K/5 speed/BDP Tranny Savers/Redline MTFin tranny/410 gears/open diff./No cat. conv./4" warped speed exhaust w/5" chrome tip/Gutted EBPV/3.5" downpipe/ Tymar open air intake/95 dana 60 / 6" skyjacker Lift/ Factory Manual hubs/HX hose/Ranch Hand Rear bumper/ Fumoto drain valve/Baldwin bypass/Coolant Bypass/Energy Suspension bushings(red)up front/bilstein 5100 shocks/Valeo clutch/31575R16 Cooper SST mt/K-9 Remote Security System/Mag Tech Diff. Cover/(ALF 6 Factory Program) TS 6 Position flip chip/Diamond Cut Headlights/203* Thermostat/Autometer Gauges/TSM Rear Disc Conversion
agomez is offline
Old 04-17-2009, 12:38 PM   #9 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Yes it can be from a bad HPOP, but not likely.
They get tired. They don't just give up unless someone threw a handfull of sandblasting grit in your engine.
Old 04-17-2009, 02:49 PM   #10 (permalink)
Excavator's Avatar
My Photos: (11)
If you are cranking over and monitor the ICP with a scanner or gauge hooked up it will show if the ICP pressure is below 500 psi. Leaking injector o rings and IPR will cause this. I see you did the IPR. Now here is how to tell if the injectors are leaking or if weak IPR or HPOP. You want to dead head the pump to see if pump is good and injectors leaking.
Dont know where to start
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 04-19-2009, 04:53 PM   #11 (permalink)
stang65fst's Avatar
"If you are cranking over and monitor the ICP with a scanner or gauge hooked up it will show if the ICP pressure is below 500 psi."
On this are you putting a gauge in there in place of the ICP? I just don't know how to scan the ICP.
"To isolate the heads as a potential large leak: 1) Remove the line from the right head and cap with a suitable plug. 2) Remove the left-hand line and connect an oil pressure gauge capable of reading 3,000 psi or greater to it. 3) Crank the engine while watching the gauge for actual pressure. If the reading is low, the problem lies in the high-pressure pump or the IPR. But to determine which is the guilty culprit, you first need to replace the IPR to evaluate. If that doesn't correct it, the pump will need replacing."
So this is just to test the HPOP an nothing else correct? Just isolating the pump by itself.
Much appreciated fella's...was in Pigeon Forge this weekend but I'll let y'all know how it turns out. Sorry if I seem ignorant, I am on this topic and just want to be educated.
Todd
AKA Toad
Old 04-19-2009, 05:02 PM   #12 (permalink)
stang65fst's Avatar
I do appreciate the thread link, I'll be going to hydro shop and get one made up.
Todd
AKA Toad
Old 04-19-2009, 05:28 PM   #13 (permalink)
Excavator's Avatar
My Photos: (11)
yes you are testing pump and IPR which is screwed in the pump and nothing else. Now if pump shows good psi as above 500 then you want to isolate one head at a time and crank it over to see if any internal leaks as in injector o rings. You cap off the line to one head and hook other line into head with the gauge hooked in line and crank it over. Be careful as it might start on one good head. If PSI is low with one head that that is the suspect side with leaking oil PSI
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
Old 04-20-2009, 05:07 PM   #14 (permalink)
MarkEkberg's Avatar
My Photos: (13)
It takes 20 min to take a valve cover off and see if a injector is puking oil out the spout.
Way easier and cheaper than making hp gauges.
Old 04-20-2009, 07:02 PM   #15 (permalink)
Excavator's Avatar
My Photos: (11)
Mark, you fail to mention that the o rings can be leaking oil and the spouts can look fine. The base of the injector has to be observed for bubbles which indicates leakage at o rings. Some times the spouts will show puking oil but not all the time.
Truck Pics
Fan clutch wrench
Camping Trips
Shifter Tube Repair
