Serpentine belt. 95 - 7.3 - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 11-30-2006, 01:16 PM Thread Starter
Proper way to relieve the tension to replace the serpentine belt.
rgift is offline
post #2 of 4 (permalink) Old 11-30-2006, 01:22 PM
PSDfreak's Avatar
Re: Serpentine belt. 95 - 7.3
There is a tensioner on the passenger side about half walf down the motor...15mm socket if I recall, with a big wrench on the socket, move it toward the left like you are trying to loosen it.
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #3 of 4 (permalink) Old 11-30-2006, 09:03 PM
Make sure that you check the idler pullies for noise. I just replaced the bearings last time I did this. Also use the old belt for a spare under the seat along with the spare CPS. [img]/ubbthreads/images/graemlins/grin.gif[/img]
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #4 of 4 (permalink) Old 10-24-2007, 09:53 PM
THANK YOU I COULD NOT FIND THIS ANSWER ANYWHERE! [img]/forums/images/%%GRAEMLIN_URL%%/mad.gif[/img] EXCEPT HERE! [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
1997 f-250 Powerstroke 4X4 Crewcab Automatic 4.10 axles
rodholt is offline
