set code po236 - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 08-04-2006, 03:56 PM Thread Starter
set code po236
just wondering if anyone know what could be the cause of this code i cleared it once and it came back again. thanks in advance.
97 F250 Supercab Lb 4x4 Auto 6pos twildman chip, tymar intake, dp with 4 inch ss magnaflow exhaust transgo tugger kit.
alex214 is offline
post #2 of 2 (permalink) Old 08-04-2006, 04:25 PM
Re: set code po236
0236* MAP Turbo boost sensor A ckt performance Uses Inferred MAP signal Restricted inlet/exhaust/supply hose,
Could be the map sensor. Located on passenger side above of engine on firewall. Hose coming from engine to sensor and wire.
If it's running fine I would clear code, drive it and see if it comes back.
1997 F350 CC,LB, 4x4, 303,000+ Hard mi.,E40D, 12.50x33x16.5 BFG A/T on aluminum, Gooseneck, Homemade Open Air Intake, Glow Plug Bypass, Door dinger gone!, 3"stainless downpipe, viper alarm w/remote start,Cobra 148, Diamond headlights, clear turn signals, homemade Brightbox mod, Silvania Silverstars,Train air horn,Beans Tranny Savers, Sparky's AIC,A/C mod, Edge evolution,WVO,WMO
Wife's ride-2001 Dodge ext.cab,360,at,4x4,pop up gooseneck, pretty much stock.
NRA LIFE MEMBER SINCE 1981
browning is offline
Gear in this thread - Powered by O'Reilly Auto Parts
