Shifter tube / plunger replacement - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-22-2009, 11:23 AM Thread Starter
Excavator's Avatar
My Photos: (11)
Here are pics from shifter tube replacement and new bushings
I knew the shifter was going to break some day but why did it brake in middle of 14 inch snow storm
I plowed with truck for 9 hours by shifting the cable with my hands after pulling cable out of bracket so I could reach from drivers seat.
Today I pulled dash apart and lowered the steering column down and rested it on the seat. Did not pull it out of truck and left steering wheel on. Once I removed the electical connections and shift pointer cable off, I was able to unbolt the column and rest on seat and could now remove the ignition switch and then remove the broken shifter tube and shaft (PLUNGER) Next I took the shifter and plunger brackets and pins off and installed on new Tube, bushings and new plunger. I lubed it up and reversed my work trying not to forget anything. When all done, the shifter is as good as new truck.
Only thing I broke in my work was the bezel snaps on the dash. It was still cold the smorning and I was not carefull enough.
Part numbers
Plunger F7DZ-7R264-AA $13.75
Shifter Tube 1F1Z-7212-AA $35.52
Bushings (2) F3TZ-7L278-A $6.28
Picasa Web Albums - jim - Shifter tube ...
99 F350 Super Duty CCLB 7.3 Auto DRW 150000 miles, multi disk converter,Hydra chip with TW tunes,ISSPRO EV2 pyro fuel trans
1996 F250 XLT Ext Cab, Powerstroke, 4x4 Dana 60, Bilsteins shocks, BTS Trans, Baby
Swamps,Tony Wildman
Chip, AutoMeter Pyro/Trans/Boost, Tymar intake, MBRP 4 in turbo back exhaust, 209000 miles,D&B HT Starter
1996 F350 XL PowerStroke 4X4 DRW, Auto Trans, Stock Work Dump truck, DDP down pipe,Tymar intake, 113000 miles
Excavator is offline
post #2 of 3 (permalink) Old 12-22-2009, 12:53 PM
Man Jim. Your hands look sore , & out side in the cold working on it too....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline
post #3 of 3 (permalink) Old 12-22-2009, 01:07 PM Thread Starter
Excavator's Avatar
My Photos: (11)
Hi Rick
Not too cold with my space heater close by
But hands still sore from shifting all day using the cable to push and pull the gears every time I made another pass and dropped plow
Swamps,Tony Wildman
